Missouri Chapter Join Chapter , Leader:77&79F250
JANUARY early thread!
Old Jan 8, 2012 | 09:45 AM
  #181
1OldFordMan's Avatar
1OldFordMan
Howdy Misery (ex) neighbors. Just passin' thru. Figured I'd see . Thinking about doing a tech post, not sure it could match up to The Big Boss Man's though. Not sure I have enough skill to match him, that light bulb WAS a pretty tricky one .
Old Jan 8, 2012 | 09:58 AM
  #182
pintoches's Avatar
pintoches
Originally Posted by zhilton
Ches, 37" radials on a trailer? That must be some kind of trailer.
Originally Posted by earthquake68
How else would you get a barbeque pit to the wheelin' spot?
It will be very simler to the two wheel trailers the pull behind the hummers! In my mind it will have a 4foot wide 8 foot long and 3 foot deep bed, heavy tail gate that doubles as a ramp 1 1/2 side rails with 3/16 plate steal sides, big round finders (maybe old step side finders), 10,000lb axle, pintel hitch, trailer breaks, led lights, 37s and wheels to match the Bronco!
Old Jan 8, 2012 | 02:12 PM
  #183
earthquake68's Avatar
earthquake68
It doesn't look like I'm getting anything done on the engine job today. These carburetors are gonna take up most of the day. I only have one done so far. I have to make a matched set for a tunnel ram set up, so I have to change somethings inside so they'll work with all that extra air. If the guy doesn't buy them, I'll have a nice set of tunnel ram carburetors for sale. (...but I hope he comes through and buys them.)
Old Jan 8, 2012 | 02:46 PM
  #184
77&79F250's Avatar
77&79F250
Moderator & parts slinger
FENDERS not finders! As in "finders keeper, looser weeper".
I have just what you need a M105A2 with a 4" C channel frame under it with 2" hitch. Can take it off and put a pintle on instead? I just need to attach my spare complete 79 D60 rear axle with leaf springs and over loads under it.
Interested? PM me. Attached are internet pics so you have a idea what I am talking about trailer wise. It's 110" long and 83" wide with tail gate.
Another project going to waste.......
Old Jan 8, 2012 | 02:48 PM
  #185
zhilton's Avatar
zhilton
How could I forget the important stuff like that.
Let me repeat it again...that's going to be one heck of a trailer
Old Jan 8, 2012 | 04:13 PM
  #186
pintoches's Avatar
pintoches
Rich that's were the idea for my trailer comes from! we might talk later but its low on the list right now!
Old Jan 8, 2012 | 04:30 PM
  #187
pintoches's Avatar
pintoches
Looked at the 37s today, JUNK! so did not buy! It tuned out to be the same guy I had been talking to for a while, he said he had not called me about the tires cause he thought I wanted better and he was right! He had a 94 power stroke bronco on 46s no fender trimming it was bad ***! had a 2000s ford f350 with 6 37s under it! And a bowtie with 52s?
Old Jan 8, 2012 | 05:08 PM
  #188
97 Mountain Man's Avatar
97 Mountain Man
Hey Ches. Can your Bronco do this?
Old Jan 8, 2012 | 06:03 PM
  #189
pintoches's Avatar
pintoches
I wish!
Old Jan 8, 2012 | 07:00 PM
  #190
earthquake68
Evening everybody!
I got the carburetors built. It took all friggin' day. They came out nice, so hopefully the guy likes them.
Old Jan 8, 2012 | 08:14 PM
  #191
77&79F250's Avatar
77&79F250
Alan are you really trying to say its done without pics......you know better. lol JK
Evening to all, and yea Ches the trailer will be right there when the time is right.
Old Jan 8, 2012 | 08:53 PM
  #192
earthquake68
They're both done, but the only pictures I took today are before and afters. I took these after I finished the first one. The second one IS done, I just don't have a picture of it yet.
They both started out looking like the one on the right. Now they both look like the one on the left.
I had to do a fair amount of repair work as well as rebuilding and tuning for the tunnel ram. Internals are set up different for a tunnel ram.
Old Jan 8, 2012 | 08:55 PM
  #193
pintoches's Avatar
pintoches
Them look like my carb waiting to be done!
Old Jan 8, 2012 | 09:05 PM
  #194
earthquake68
I have plenty of parts for them, that's for sure. I thought I had four of them, turns out I had these two and a couple parts carbs.
I still have a 625 Carter AFB, a 700 Holley dual feed double pumper with mechanical secondaries, and a 750 Vacuum secondary Holley with a four corner idle circuit.
I may have enough gaskets and pieces to rebuild your carb without buying any parts. I'd have to check, though. I need to get another super kit. I'm running out of different squirters, power valves and accelerator pump cams. I could use another jet kit too. Some of my smaller jets I'm running low on.
Old Jan 8, 2012 | 09:08 PM
  #195
pintoches's Avatar
pintoches
I got a kit, and got mine half way built, but need a clutch bit, borrowed it fro about 10 mins, forgot one gasket so need to get one again, so I can finish it!
