mines fiberglass and i have not found any leaks from either heavy rains last summer or this spring after sitting with snow on it all winter.
The problem is, like ours, is you don't see the leaks. I never once actually saw water in my TT either and thought all was well until one day my wife said the floor on her side of the bed was soft. Not long at all after that I noticed the floor by the door getting soft. At that point it is to late and the soft spots need to be replaced.
Although like I mentioned and I am 99% sure now that the water didn't "leak in" but found its way in threw small holes in the tarp covering the bottom of the trailer while pulling it down the road in wet conditions. These things are slapped together it seems by blind people. The holes in the tarp are mostly from missed staples holding the siding on the bottom edge. the other problem I see and do know about with these type of weaved plastic tarps is after a few years the weave starts to separate a bit and the tarp basically does nothing anymore beside let water in and hold it in.
This is the reason why I would like to coat the underside with something to seal up the tarp better. The problem I see though is not much of anything likes to stick to a plastic tarp material.
Ours was leaking from the bottom somehow, I noticed a bubble in the wallpaper and pushed it with my finger and poked through the wall. Then I went around the whole camper and it was the same way. Soon after the fiberglass started bubbling up here and there and on the way to trade it in the front corner blew loose and insulation went everywhere.
They still took it though. It was a '97 model so I'm sure they make them better now.
Mines also a '97, but its spent most of its life parked. it did go through a flood some years back at my uncles place with salt water. Amazingly though the frame, wheel bearings..ect all look good. i do have a soft spot in the floor but i braced it up from the underside with heavy gauge steel angle. I bought it for $1k everything works and it will be fine for the camping trips i have going on…if it fell apart totally in 2 years i would not shed a tear.
Yeah, I bought mine used for $7k in 2002 and traded it in in 2011 for $3500, used the hell out of it so got my moneys worth out of it. Also kept it stored at the beach so I'm sure that didn't help haha.
Ours is a 05 that we scored on for $5500 about 4-5 years ago now. It is in great shape besides the floor sections I replaced. The original tires on it had almost like new thread on them even.
But, I'm going to have to make a guard/skid plate for the black water drain. If I wasn't paying attention I would have ripped it off. Got a little sand on it though.
It pulled nice this trip, even though my second trailer has only about 100 lbs of toung wt.
Hmm, that is different than mine. Mine looks, feels, and acts like plain plumbers putty. Gray in color, pliable like play doh, all the same symptoms like putty.
I'll try to get some pics later on today when playing with it. Maybe it is just the one lower joint that has the putty and the rest is silicone.
My old camper had that putty stuff on all the ends, and windows. I had to go around the windows with silicone to seal it back up. They had leaked and made the walls soft under a couple of them.
That does bring up another question I have with campers. I am positive some makes are better than others. Is there a list of the better built ones? Like this deal with silicone sealant over the putty stuff. I also notice many of the small doors on my camper are sealed with what seems like topper seal, that foam stuff. All another reason I am thinking of getting an airstream or the like and tearing it all down and rebuilding it myself.
That is butyl putty, think they used to use it alot and it is still sold in rv stores.
I pulled it out of my front corners and applied silicone sealant from a home center.
It started seperating after the 1st trip, pulled that and used sealant specifically for rv's.
Much better/stronger product and not too expensive, several trips no peeling or leaking http://www.campingworld.com/search=sealant
