The camper thread! Pulling, using, equipment, maintenance!
#586
#587
#588
Fully loaded (camper, gear and people) I was still in the safe zone with the 150, but just. I knew the Ex with that 7.3 would be awesome but it was a totally different world. Just another reason to love the Ex.
#589
#590
#591
So my lights inside the camper are 1156's. I want to install led's and I see on ebay you can get anywhere between 5 to 100 smd's for the same price it seems. Are the smd led's the super bright ones or are there better yet? Which ones do you get for interior TT lighting?
#593
This pic it's totally dark outside. N only 3 lights on inside.
#594
Thanks for the pics! Are those strips one continuous light or are they little blocks next to each other?
I don't mind rewiring my lights if I get some led's I know are up to the task.
#595
#597
#598
Speed related. So the wind is pulling it out. Yes under warrenty. I'll be taking it in next week.
#599
#600
Dragged the camper trailer to the homestead to do a thorough cleaning inside after the last trip and to repair a small seeping in the fresh water tank.
Ordered a new tank because I could not find the source of the leak (man vision according to my wife...I can see a quail in my peripheral about 35 yards to my left, but can't find the mustard in the refrigerator).
Trying to get the old tank out, one effin' wire would not dislodge, so I thought just cut the wire and splice the new tank wire. Set the new tank on top and it was the correct size but the connections were on the wrong side.
I begin to remove the tank here is a tip:
Mark which color wire with a sharpie for re-installation see pic.
Upshot- I received the wrong tank, correct size, but connections on wrong side see pic of new tank on old tank.
Result: the drain was completely gone. The hose and outside valve gone and the tank worked it's way out of the retainers on the floor.
Solution: attach drain tubing, using clamps with valve and mount a bracket on the bench seat to prevent the tank from repositioning in the future. I also added clamps to all other tubing that did not have clamps and repositioned clamps for future removal.
Once again a 90 minute job takes 4 hours with travel to the hardware store. But it's better now than before.
Used a Sharpie to mark which color wire to the correct post. Missing drain tube center.
Correct size tank but they placed the connections on the wrong facet. 90° in either direction would have worked.
Drain tube in place.
Clamped hoses that were not clamped and clamped others in a friendly method (I can get to them).
Outside valve and tube was completely gone, probably because it was not clamped. Replacement on right.
