The camper thread! Pulling, using, equipment, maintenance!
Old Apr 19, 2014 | 11:42 AM
  #481
hav24wheel's Avatar
hav24wheel
Got my extra jacks mounted. Drilled and tapped the frame, put two bolts in each and one self tapper that was in the way. Lol. Red lock tight on the bolts.
Old Apr 19, 2014 | 08:07 PM
  #482
Snowseeker's Avatar
Snowseeker
Just finished replacing the floor by the door, next is the floor by the bed (front of camper).
I have come to the conclusion that the water didn't leak in from rain or snow or any overhead precipitation but from driving down wet roads. I can see now that "tarp" they use to seal water out from the bottom does hardly anything. There are so many holes in the tarp from missed stapes at assembly, even the weave itself has some separation.
I have come to the conclusion that if you don't want floor rot don't drive on wet roads (during rain).
I would like to seal the bottom with something different. What can I apply to the bottom side of the "tarp" to help seal out water if we ever do have to drive in the rain?
Old Apr 19, 2014 | 08:17 PM
  #483
hav24wheel's Avatar
hav24wheel
I was layin under mine thinking the same thing.... Mine has a enclosed underbelly, so I'd have to worry about just the stuff on the outside of the frame rails. Especially over the tires. Thought of mounting some single axle trailer fenders over each wheel to keep impact to the bottom of the slides to a min... Idk, what you could spay/roll onto the bottom.
Old Apr 19, 2014 | 08:57 PM
  #484
ExxWhy's Avatar
ExxWhy
Took the cover off mine today. Thinking about new flooring and carpet in mine this spring. Shouldn't be too bad of a job, not too many sq feet! Pics when I get it done.
Old Apr 20, 2014 | 08:39 AM
  #485
Snowseeker's Avatar
Snowseeker
Mine at least has plastic wheel wells so nothing gets effected there but the whole rest of the underside is just that black plastic crap. The main areas that got wet and rot was at the front side of the camper I assume from tire spray from the X/truck and then behind the trailer tires where again tire spray off the trailer tires.
I really would like to be able to spray something instead of roll it on but I won't be to picky if whatever I use will actually work.
Maybe that flex seal stuff you see on tv with the guy in the boat with a screen door for a floor.
If it were all just flat on the bottom I would be willing to put in some sort of aluminum or plastic sheeting. But like most the frame sticks down which I could still sheet in the center section easily but the outer sides have tapered braces off the frame which would make sheeting sit funny and be hard to seal at the sides of the camper.
I can see why some people build their own campers from the frame up. They use the absolute most cheapest materials in these things. And while I assume allot of it has to do with weight there are places I personally wouldn't have skimped.
That airstream builder idea is starting to look better and better.
Old Apr 20, 2014 | 01:42 PM
  #486
hav24wheel's Avatar
hav24wheel
A spray on bed liner would prob work nice too.
Old Apr 20, 2014 | 01:57 PM
  #487
UFMcG's Avatar
UFMcG
Saw this at Home Depot last week. Probably not as durable as bedliner, but may be easier to apply.
Rust-Oleum® NeverWet® Liquid Repelling Treatment
Old Apr 20, 2014 | 02:32 PM
  #488
hav24wheel's Avatar
hav24wheel
That might be the ticket right there!
Old Apr 20, 2014 | 04:02 PM
  #489
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
That stuff is terrible, don't waste your money. I threw mine away.
Old Apr 20, 2014 | 04:46 PM
  #490
UFMcG's Avatar
UFMcG
What'd it do? I was thinking about getting some to play with, but if it's that bad I'll heed your advice.
Old Apr 20, 2014 | 05:54 PM
  #491
hav24wheel's Avatar
hav24wheel
I've read good reviews about it. Seems depending on the surface, it requires diffrent application ratios to work the best
Old Apr 20, 2014 | 08:14 PM
  #492
Snowseeker's Avatar
Snowseeker
I bought some of that never wet. It is a two part system and needs to be redone "when needed" or every year or so. Still doesn't plug the holes and stuff either.
Has anyone used that 'Flex seal' stuff? That sounds like a good deal as long as it would stick to the plastic tarp stuff.
Old Apr 20, 2014 | 08:45 PM
  #493
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
It drys real tacky, wears off if you rub it and it stains surfaces. You can't use it on anything that will be touched or it will wear off. I have no idea where any use of it could be used where you or anything else doesn't touch it or if you don't care about it changing the appearance of it. Also doesn't work on cloth or canvas, carpet or really slick stuff.
No way it would work as a bed liner. Get a can of it and read the fine print. I wish I did.
Old Apr 20, 2014 | 09:43 PM
  #494
hav24wheel's Avatar
hav24wheel
I've tried it on a cast iron pipe once that had a crack on it. It worked for quite a wile that started to seep again. But I only layed on one heavy coat instead on mulitpul thin ones.
That doesn't sound good at all.
Old Apr 24, 2014 | 06:40 PM
  #495
2006lariat's Avatar
2006lariat
I hate packing the camper, especially for the first trip out. It was a whole lot easier when my checklist was Beer, check, 6pack of Hoagies, check, Sleeping Bag, Check!
With the children, now I have to buy more beer, and more Hoagies!
