Missouri Chapter Join Chapter , Leader:77&79F250
March MO Chapter Chat/ BS Thread....all welcome.
Old Mar 24, 2011 | 12:33 PM
  #691
Cerpindicular's Avatar
Cerpindicular
bob if you get bored and tired of trying to break your mounts loose and still want to help with the short issues i am having give me a call or stop by i should be here all day i believe.
Old Mar 24, 2011 | 01:22 PM
  #692
Cerpindicular
ha i'm a idiot sometimes...brake lights were out because i pulled the fuse from them without knowing it and used it as a turn signal fuse and put the burnt fuse back in it and forgot all about it. So power to the switch had one brake light on went to pull the bulb to check it and the dang bulb seperated on me put the one new bulb i had in it to test and it didn't work went to take it out and it did the same thing...pulled the bulb from the other socket to try to test it in that socket to make sure the bulb wasn't damaged and i just didn't know it and it did the same damn thing again....looks like i am going to have to hit oriellys for some bulbs and maybe i should replace the sockets while i am at it. looks like somone replaced the passenger side brake light socket already (the one that wasn't working when i had good bulbs) and 1 of the 3 wires had fallen out of it and was kind of bouncing around so maybe that was my short.
Old Mar 24, 2011 | 02:55 PM
  #693
whiskey runner's Avatar
whiskey runner
thats true brian..bare wires bouncing around are never a good idea. what color was the wire that fell out..black is ground brown is park lights green or yellow is turn/brake lights...would be a good place to start your repairs..while you are there give the rest of the wires,sockets and connection plugs a good eyeballing
Old Mar 24, 2011 | 02:59 PM
  #694
whiskey runner
with that many bulbs breaking like that..are you sure you are turning far enough before pulling out and in the right direction and the offset studs are in right grooves..just a thought
Old Mar 24, 2011 | 03:13 PM
  #695
cyclopsblown34's Avatar
cyclopsblown34
Brian, the hammer just gets the glass part out, it leaves the irritating little metal piece in the socket.
Old Mar 24, 2011 | 03:17 PM
  #696
larryb346's Avatar
larryb346
Not sure if any of you guys might have a use for it, but I am gonna haul a 84 cab to the crusher pretty shortly. The front end is out and also the bed. none in good shape. Buddy bought it and wanted me to make him a trailer and he had another good bed so I cut the frame about mid cab.
Larry
Old Mar 24, 2011 | 04:22 PM
  #697
tcbofade's Avatar
tcbofade
Originally Posted by larryb346
Not sure if any of you guys might have a use for it, but I am gonna haul a 84 cab to the crusher pretty shortly....
Hmm. I don't need an entire cab, but if the dashboard is intact, I could use it. Do you have the seat for it?
Old Mar 24, 2011 | 04:23 PM
  #698
tcbofade's Avatar
tcbofade
Originally Posted by whiskey runner
if anyone stole my truck..they would bring it back and whip my *** for leaving it there...
Me too.
Old Mar 24, 2011 | 06:00 PM
  #699
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Whew long day in and all around Spg, and Republic. The mother-inlaw doc appt went ok still has some test to run.......no definite answer yet.
Well looks like I might be on the road on or around the 2nd, dang I did not want to go back to work.
Old Mar 24, 2011 | 06:26 PM
  #700
Cerpindicular
no go on the wire that was bouncing around that i fixed still shorting out when i use the blinkers but i have my brake lights back now.
Old Mar 24, 2011 | 06:31 PM
  #701
ubereal2's Avatar
ubereal2
He said BLINKER AGAIN!!!!!!!! It's a Turn Signal!
Old Mar 24, 2011 | 06:33 PM
  #702
Cerpindicular
lol if you came and fixed it for me so i dont have to then that would stop me from saying BLINKER. I drove that dang thing to springfield and then across town for my drug test for work then home and the fuse didn't blow till i was pulling in my drive way. Fixed my brake lights put in a new signal fuse and it blew pulling out of the parking lot of oriellys as i was leaving. Its completely random and sometimes it will blow them back to back as soon as i put a new one in. I hate wireing...why can't it be like my bike was i think i had maybe 5 or 6 wires all together on it.
Old Mar 24, 2011 | 06:42 PM
  #703
ubereal2's Avatar
ubereal2
Brian, if I got out there, and so help me..... And You say "That word" I'll leave so help me I will! Everybody has one little thing that bothers them. Mine is without a doubt THAT word.
Congrats on the job situation. They are hard to get right now.
I know an older guy (older than me even) that heard a so called mechanic call a push rod, and "Push Tube". He came un-wound.
So lets see what one word bothers us. You all know mine. Chime in!!!!!
Alan good to see you again this afternoon. Hopefully you'll see a difference in Ka'Bluey pretty soon.
Y'all have a good one, I'm gonna feed my neck!
Unk Bob
Old Mar 24, 2011 | 07:12 PM
  #704
Cerpindicular
thats easy chevy blazer
Old Mar 24, 2011 | 07:21 PM
  #705
earthquake68's Avatar
earthquake68
I'm neurotic, I have lots of things that get under my skin.
There they're and their. USE THE CORRECT ONE!
There-it's a place, like over there!
Their-possessive. It belongs to them, so it's THEIRS!
They're- Simple, it's short for THEY ARE!
To, too and Two. Again, use the correct one!
To-conjunction. To get something done or get from here TO there
Too- Can be used in place of ALSO. "We went there, too"
Two- It's a number, it comes after one.
Flexplates go on automatic cars. Flywheels go on stick cars.
A MOTOR is an electrical device that converts electricity into kinetic energy.
An ENGINE has lots of internal explosions to move pistons up and down to turn a crankshaft.
And a sure way to get me to come apart at the seams in one second flat.....
If a vehicle stops running, or starts running poorly IT'S PROBABLY NOT THE TIMING!!!!!!!
Something is not running right and some moron will want to immediately spin the dang distributor. Leave it alone and troubleshoot the problem, slap nuts!
Whew, ....ok. I think I'm done now.
