Missouri Chapter Join Chapter , Leader:77&79F250
March MO Chapter Chat/ BS Thread....all welcome.
Old Mar 13, 2011 | 09:58 AM
  #301
pintoches's Avatar
pintoches
Day two of the caviler engine swap! If any one wants to help come on over!
Bob looks like there is more than one choice,
Federal-Mogul Resource Center - Vehicle Look-up
Old Mar 13, 2011 | 11:36 AM
  #302
whiskey runner's Avatar
whiskey runner
just starting pinto?? the day is half over already
Old Mar 13, 2011 | 02:24 PM
  #303
Cerpindicular's Avatar
Cerpindicular
hooked up the coil filled it with oil shot a little oil the best i could into the cylinders hooked up the plug wires and it fired. Little smokey at the moment and i can't decide if its got a knock or not since i have the exhaust unhooked so its hard for me to tell but it did fire up. so wooohoo
Old Mar 13, 2011 | 02:42 PM
  #304
whiskey runner
thats good cerp..it will smoke for awhile till it burns the oil out of the cylinder's.. now you need to be sure you got all the bolts in tight everything hooked up correctly and full of oil and coolant..it shouldnt knock ran very quiet in the other truck..may take a bit to get the lifters pumped up,air worked out of the p/s and maybe a bit of tuning...you should be driving tonite..now get back to work..
Old Mar 13, 2011 | 02:48 PM
  #305
pintoches's Avatar
pintoches
got the motor out! new one in in place bolted down, lunch break! still got to put both manifolds, alt ac and ps so about 3 more hours buy myself!
Old Mar 13, 2011 | 03:10 PM
  #306
earthquake68's Avatar
earthquake68
Woo Hoo, Cerp! Way to go. Now put the bell housing bolts in, get the exhaust lined up and bolted together, and finish everything else up!
I may swing by to pick up the old parts for Whiskey. I'm not sure yet, though. Just try to keep them dry. ...I should've grabbed them when I had the chance.
Old Mar 13, 2011 | 03:12 PM
  #307
Cerpindicular
did get much more done today since it started to rain did get the fan and belt back on it fired it up to make sure everything worked right and knock i was hearing was all but gone so i guess i was just imagining it plus like i said the exhaust is still disconnected so its hard to tell anyways. If you get a free moment earthquake you could always take a look at it and make sure i got the timing right and everything on it and i bagged the old block up pretty good to keep the rain out of it. We did make one goof my valve covers need to be reversed on the blazer they were on opposite sides and i did think about it while the engine was out and they were easy to get to.
Old Mar 13, 2011 | 03:13 PM
  #308
Cerpindicular
i got them all moved under the carport except for the block which is bagged pretty good now to keep the rain out of it.
Old Mar 13, 2011 | 03:14 PM
  #309
flyer122's Avatar
flyer122
Good afternoon MO.
Old Mar 13, 2011 | 03:48 PM
  #310
Cerpindicular
missouri weather sunburned yesterday drown today freeze tomorrow good times....
Old Mar 13, 2011 | 04:14 PM
  #311
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Well sounds like some folks have been real busy today, I just can't get over my jet lag.
But I have some busy days scheduled ahead........
Old Mar 13, 2011 | 04:28 PM
  #312
whiskey runner
we had a good day down here in the sunny south.....feel sorry for you yankees up north.ha ha ha.. looks like pinto and serp got a little done today..i got lazy and just stayed home..but tomorrow is another day..might even try to get something going to take to smorr this week-end.. the grandson wants to play with the bronco we fixed up for him
Old Mar 13, 2011 | 05:29 PM
  #313
earthquake68
That Bronco looks like it would be hard to get in to.
Old Mar 13, 2011 | 06:02 PM
  #314
ubereal2's Avatar
ubereal2
I wasn't as productive as others, BUT Tim and I had a good day together. We made it out to Bass Pro and killed some time. Got us some new Crappie jigs, weights, bobbers, etc....... Went by AutoZone (by the way is usually full of idiots) and got the CORRECT radious arm bushings and oil change for Ka'Bluey.
Allen hollar when/if you make it out to Cerps place, and don't mind a tag along, or if Tim wants to come out too, and if you don't have room we'll just fallow. Ka'Bluey is grounded untill we get the oil, and radious arm bushing done.
Rich get over that jet lag, pick them feet up yell "UNK BOB"!!!!!!!!!!!!!!! and we'll get you going again!
Y'all have a safe great evening!
Unk Bob
Old Mar 13, 2011 | 06:16 PM
  #315
77&79F250's Avatar
77&79F250
Will do there Unk Bob, I am thinking wednesday get on the bronc, mon/tue I have a few other home projects to finish.
How does you and Tim's schedule look for a trip north on wed? I need to drop and clean out the rear tank and finish the exhaust, install a batt box, and finish a little wiring.
And.....want to change out the carb with one off ol red its a Edelbrock 600 manual choke with a "off road" kit.
And take it for a mini shake down run on my bro-inlaws property, are ya game?
