- have spark, won't start, thinking a weak spark..
- Need Advice with Duraspark Troubleshooting
- Cruise control add on / modification
- Which Sensor Retards Timing?
- Knock Sensor???
- 1968 shop maual (wiring diagrams)
- pwr. wndow conversion kit?
- driving/fog light install
- Ignition problems '90 Ranger
- Stray alternator wire
- Trailer hookup and turn signal prob.
- Building a transistorized points setup from tech article plans
- Windshield washer squirter
- Electronic shift 4WD not engaging
- weird problem with trailer wiring harness
- Fuse/Relay Block
- 91 Ranger dead sometimes
- Short somewhere
- odometer reading
- Dome light override?
- Electrical???????
- Windshield wipers
- coil wire hook up
- licence plate light
- electric brake wires
- Wiring harness from Distributor to Firewayy
- engine miss under load
- '88 F250 Power Locks
- How do you Disconnect Daytime Running Lights
- Dura spark wiring diagram
