- Starter problems on a 1977 460 cid
- Alternator Question
- Need to adjust timing with MSD?
- alt hook up
- Battery charging unless I am using accessories!
- Ford Dura Spark II Ignition System
- Hot Wire - Old truck question
- No Spark
- 1988 F150 302 5.0 Fuel pump runs when ignition is off.
- Need help ASAP!!! Panel Illumination gone :(
- 4x4 light
- HELP! Cd player in 83 f250
- 1992 E350 Rear Turn Signals/Cruise control don't work
- Wiring an extra power port and an inverter
- Screwy U R THE MAN ThANK YOU.
- Ignition Switch Malfunction
- alarm/remote start problems
- power door lock not working
- Q for Franklin2
- Which ignition system do I have?
- odometer help please!!
- running rough
- Can you swap EDIS ignition?
- no power to cab
- Tfi Modual Question
- Add-on alarms for SD
- alternator 79 f-150
- Keyless door locks
- Awesome Headlights
- EEC Fuse keeps blowing
