Building a transistorized points setup from tech article plans
Old Jan 12, 2002 | 11:22 PM
jlasater's Avatar
jlasater
I'm looking at building a transistorized points setup that was posted in the tech articles section (appears to be a broken link now). Have any of you guys built it? Just wondering if I should remove the ballast resistor to the coil so that it runs 12V all the time. There appears to be a resistor inline with the points, so I'm thinking they won't get full voltage or current and should last longer.
Old Jan 13, 2002 | 12:42 AM
sparky's Avatar
sparky
Never tried that conversion...but why not swap in a Duraspark system or replace the points with the Petronic module? If you live on Vancouver Island I have just the parts truck you need to upgrade your ignition to Duraspark
Sparky
Old Jan 13, 2002 | 01:28 AM
Franklin2's Avatar
Franklin2
Yea, I wouldn't re-invent the wheel. Duraspark will work great. By the way, they still use a resistor in the coil circuit on a duraspark, with a bypass for starting.
Old Jan 14, 2002 | 01:10 AM
jlasater's Avatar
jlasater
Looking at the parts list, the project would be about an hours worth of work, and I'd pot the parts in epoxy to keep anything from vibrating. Plus, it's be a fun project. If I go as far as to replace the whole ignition system, it'll be MSD all the way :-) But that's more money than I wanna spend on a stock truck at this point.
Old Jan 14, 2002 | 07:10 PM
Highper4mance's Avatar
Highper4mance
asavage
Aerostar
15
Jul 11, 2016 09:24 PM
oldmanXJ
Aug 2, 2013 06:50 AM
1stfordtrck
Jan 6, 2005 10:00 PM
Stagecraft Chris
Garage & Workshop
Oct 24, 2003 12:30 PM
