engine swap, 04 5.4L into 2001 SD
Old Jul 31, 2010 | 03:11 AM
madhattervr4's Avatar
madhattervr4
I blew the engine (5.4L) in my 01 SD and found an 04' 5.4L for a good price, is this going to be a nasty swap or pretty easy? Is there an engine removal guide for the 01 SD gasser?
Old Jul 31, 2010 | 03:15 AM
madhattervr4
oh and the 04' 5.4 is from an f150
Old Jul 31, 2010 | 05:24 PM
khxor's Avatar
khxor
Depends if the F-150 got the 3v engine in 2004. I put an 04 5.4 from an excursion into my 99, but the ex. never got the 3v.
Old Jul 31, 2010 | 05:43 PM
tawells01's Avatar
tawells01
I believe the 2004 F150 came with the 3V 5.4L, so this won't be as simple a swap as installing another 2V engine. You are going to need to change out the PCM (you will need one from a 3V 5.4L super duty), etc.
Old Jul 31, 2010 | 09:25 PM
madhattervr4
it is a 3v, is the wiring harness the same?
Old Jul 31, 2010 | 09:27 PM
Johnny Langton's Avatar
Johnny Langton
No,it's nothing even close to the 2V.
JL
Old Aug 1, 2010 | 04:15 AM
khxor's Avatar
khxor
Yeah a 3v swap is gonna be far more hassle than 2v, aren't they drive-by-wire too? If you find yourself a 2v it's not too complicated a job. depending on what it came out of there will be parts you have to swap from your truck, I've posted what I had to swap onto my new engine before in this forum, so if you want to see then try a search, might not be exactly the same for you, but it's gonna depend on the donor truck. take pictures every step of the way on disassembly, label every single connector. If yours is a stick don't pay any attention to anything that tells you that you need to remove the transmission first.
Old Aug 1, 2010 | 09:06 PM
madhattervr4
So basically, I would need a 2004 super duty ecu and wiring harness because a SD isn't drive by wire like the F150 (yes the f150 is drive by wire, I have the throttle body from the f150)? what did you label your thread when you did the swap? I've tried searching and can't find anything.
Old Aug 1, 2010 | 09:18 PM
m-chan68's Avatar
m-chan68
To the original poster in this thread, forget about the idea of even THINKING about this swap and continue your search for another 5.4L V8 2-valve engine. There are way too many differences between the two engines to even make it a worthy consideration. As a Ford dealer tech, here are the KNOWN differences:
-ETC versus mechanical throttle body
-returnless fuel system versus conventional return type
-3-valve VCT heads versus 2-valve heads
-Motorola type PCM versus Ford PCM
-4R75E transmission versus 4R100 transmission
Just by virtue of what I've mentioned above, this swap will become a total disaster to wire up, and fabricate parts needed to make functional. The minimal gains of the 3-valve engine, over and above that of the 2-valve engine hardly make it even worth considering.
Old Aug 1, 2010 | 10:47 PM
Moto Mel's Avatar
Moto Mel
If you can or want to you could change the top of your engine to the 3 valve engine and not worry about wiring and fuel lines, etc. The head gaskets are the same as per Auto Zone.
Old Aug 2, 2010 | 05:56 AM
madhattervr4
Enough said. thank you!
Frozen001
Oct 4, 2016 07:14 AM
Dtaylor85
Aug 25, 2014 07:14 PM
gtex
Modular V8 (4.6L, 5.4L)
Jan 3, 2011 02:24 PM
grandfathersgarage
Dec 23, 2008 09:43 PM
medtech
Oct 23, 2005 02:13 PM
