ques. for those runing aftermarket camshafts
ok so this actually isnt for my truck, its for the wifes mustang but its a ford 4.6 so it still counts! my anniversary is this friday and she wants cams for that drag racer lumpy bumpy idle, but I dont want to change pistons to accomodate a massive lift cam.
also, the car will be a daily driver for at least another year so i can't have anything terribly outrageous in it, it still needs to have some juice at the 2000rpm mark. it is a 2001 PI heads SOHC.
so, who has cams that idle like $#!T but won't require me to put 4.11's and notched pistons in it?
i keep getting mixed opinions on the comp cams xe274h from all the stang guys, but i am leaning towards those currently.
Look into compcams. I think the XE274H is what you want if a 5-speed.
All use the same .550 lift so no piston changes needed. Might want better valve springs to be safe though.
COMP Cams: Xtreme Energy™, XE274H <BR> Hot Street, Rough Idle
JL
thats pretty spot on what i was thinking!
i know you dont buy a cam for idle, but the car slowly ($$$) will be built around the cam. heads and intake manifold are in the near future, exhaust and CAI are done already. its a 5 speed and im putting 3.73 in it to replace the 3.27 stock ratio. wifey loves that full on race car sound, so i'd like to get close at least to make her a little happy. do you have any sounds clips of the 270 at idle? it sounds smooth when i listen on youtube.
a comp cams rep got back to me and rec'd the xe268h. he said it will still idle rough. youtube does not get me a good average of what the engines sound like with that cam. i would love it if i could put a smaller cam in and still have it shake a bit.
with an sct programmer could i keep the idle down at 750rpms rather than 1000 to let it break up a bit more for her?
JL
Here you go-this was the after the first start post engine build and is idling at 800rpms.
<param name="movie" value="http://www.youtube.com/v/e7zL-LO7jjg?fs=1&hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/e7zL-LO7jjg?fs=1&hl=en_US" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385"></embed>
Shadow944795
05-22-2015 01:23 PM
Macrobb
09-16-2014 11:18 PM
mustange70
16
07-16-2006 05:46 AM
76 F250 4X4
11-07-2004 11:42 AM
