- water leak coming from dash
- Exhaust
- Parking break problem
- The grinding won't go away!
- F150 misses hard after startup...then fine
- Anti freeze under the intake
- Low RPMs
- Deer vs 99 f150
- 2001 4.6 supercrew 123,000 miles need help!!!
- Multifunction Switches
- Bad Break Caliper?
- High pitched wine
- steering column shaft loose????
- nasty noise and jolt from rear
- tire size issues/ rear higher than front
- Lifting250ld's
- Gears and mileage
- CV shafts
- everytime it touch the brakes
- Tie Rod will not come out
- auto light sensor
- High performance distributor and coil pack??
- Front end shimmy
- 2000 Lariat headlights
- Power mirrors--not moving in right direction
- Dome light problem
- alternator,how to replace
- p1409 Service Engine Soon
- Bolt Pattern for 00 F150 4x4
- bolt pattern on 03 vs 05 4x4
