Sponsored by: Auxito
p1409 Service Engine Soon
Old Nov 4, 2006 | 12:09 PM
bigpapii's Avatar
bigpapii
Hey the other day i was messing around in my truck going down a dirt road with a couple puddles and stuff..... about 2 hours later after i left i was driving my truck when the service engine light came on.. The code is p1409.... EGR did offroading mess something up? or is it a easy fix like something loose? i have a 1999 f150 v6 2wd thanks
Old Nov 4, 2006 | 01:20 PM
Baja FX4's Avatar
Baja FX4
Thumbs up
Is it EGR insufficient flow,or excessive flow?
what does P1409 exactly mean,I can help you better if you describe it more.
Old Nov 4, 2006 | 01:50 PM
bigpapii's Avatar
bigpapii
this is all i know
P1409 = EVR solenoid unplugged or defective, defective PCM, or there is an open circuit between between the PCM and the solenoid.
Old Nov 4, 2006 | 03:20 PM
projectSHO89's Avatar
projectSHO89
this is all i know
Umm, yeah, that's the exact answer I gave you on a different forum....
Old Nov 4, 2006 | 03:30 PM
bigpapii's Avatar
bigpapii
yes i know i was using the information you gave me so some one could help me figure out the full problem and what might of happened
Old Nov 4, 2006 | 06:46 PM
AzBlueWolf's Avatar
AzBlueWolf
check to see if you got dirt or water into the egr valve and it is sticking open or shut
check to see if everything is plugged in (sometimes connector locks break when you disconnect them)
check the wires at the connector...tug lightly on each wire seperately to see if it comes out of the connector
Old Nov 4, 2006 | 09:12 PM
Baja FX4's Avatar
Baja FX4
The code means that the PCM is sensing an open in the EVR circuit.
This is what i recommend you do,disconnect the EGR vacuum regulator electrical connector and with a Voltmeter check resistance across the terminals at the EVR.
If you get no continuity,EVR has an open internally,replace it.
If you do get continuity,then disconnect battery then PCM.find out with two pins at the PCM connector are the EVR and check for continuity from PCM to EVR and both wires.
If Both are ok,then PCM is bad.
Simple,isnt it?
Hope that helps
Old Oct 15, 2012 | 07:32 AM
jondow's Avatar
jondow
I had a p1409 code and I ended up replacing my EGR solenoid valve. Valve apparently had become gummed up and was sticking open (coil resistance was within spec 20-40 ohms). Cost about $25.
melissar
Escape & Escape Hybrid
15
Jul 13, 2019 05:07 PM
melissar
New Member Introductions
Sep 30, 2016 10:27 AM
1egg1basket
13
Sep 26, 2016 11:17 PM
Hhredneck
Southern Region
Mar 31, 2016 01:46 PM
Wkbrdr1
Mar 12, 2011 11:04 AM
