- 4.6l intake manifold torque pattern and amount of torque?
- super charger
- Getting a popping, back fire through the intake!!!
- CD magazine
- very slight miss
- Help with Neon Underbody kit
- 5.4l Misses/Shudders at very low spd.
- Dtc 1507
- max speed cutout
- Thinking about going with a synthetic oil.
- How much of a restriction is the stock muffler?
- What is the thermostat rating for the 4.2?
- which exhaust system is best?
- moisture buildup in oil fill pipe
- lemon law issue
- Humming noise coming from steering column/ odometer panel
- Lightning suprcharger in 5.4L same year model??
- 03 Door panel removal, speaker install
- Should I get new plugs, 97 F150 5.4 with 75,000 miles?
- Po171 & 174 Too Lean
- Over Drive Light Flashing?
- How many horsepower (stock) do F150's have?
- 98 2wd body lift
- What are codes for the ring and pinion gears?
- Oasis?? Carfax anyone...
- 4.6-5.4 Suspension
- Mac Intake
- Is it supposed to be like this?
- trouble codes
- Cheap Shocks
