- factory 7 way plug
- too much water from 5.4 tailpipes.
- One bearing wonder
- Spare Tire
- VIN decode
- More Power for 1997 5.4
- Flashing air bag light
- Differential Gears
- PCV.....bad fuel mileage?
- plug blowing now causing FIRES!
- Dual exhaust recommendation for 97 F150
- Air Conditioning problem
- Shudder
- 97 F-150 worth?
- A/C Troubles?
- Predator Question for '03 5.4
- major problem
- front u joints on 1999 f250
- Drive Shaft Removal / Slip Yoke Lube
- 98' 5.4L transfer case oil
- The new lift,rims and tires,5.4L pulls fine
- Brake Problems
- Differential Woes Need Help Bad!!!
- Knocking Sound
- The right way to unplug connectors
- Start up chatter
- Truck will not start, turn key nothing
- She needs lubed!!
- Need help bad, no power to fuse block
- Trouble starting
