Sponsored by: Auxito
everytime it touch the brakes
Old Nov 5, 2006 | 01:04 PM
f-250.4x4.390's Avatar
f-250.4x4.390
Everytime i hit the breaks i hear a pop in the front left of the suspension.
i've jacked it up and wiggled the wheel in every imaginable direction and nothing seems to be loose, what else can i check, and what is the best way to check it.
Old Nov 5, 2006 | 02:12 PM
LxMan1's Avatar
LxMan1
Tie rod end, ball joint, loose caliper, control arm bushings?
Old Nov 5, 2006 | 06:07 PM
steve(ill)'s Avatar
steve(ill)
put the jack under the A frame and lift one side at a time. you need the weight of the truck setting on the a-frame, not on the jack. wheel should be in mid stroke, not setting on the lower or upper ball joint. ----- with tire 2 inches off the ground, put a 4 ft 2 x 4 under the tire edge and pry it up and down. look at the ball joints on the back side top and bottom for slop. migh ttake a buddy to do this and look also.
