Sponsored by: Auxito
A/C Troubles?
Old Mar 25, 2007 | 06:49 PM
Braker 19's Avatar
Braker 19
Unhappy A/C Troubles?
When I pull up to a stop sign or light with the a/c on, once in a while it will run horrible. Misses, shakes, and stumbles on take off. If you shut the air off and gun it a couple times it runs just fine. Only does it with air turned on, and only does it a couple times a summer. Any ideas?
Old Mar 25, 2007 | 08:36 PM
ubereal2's Avatar
ubereal2
Running the A/C puts a huge drain on the engine.
I'd most likely start looking at spark plugs and wires. You'd be supprised.
Bob
Old Mar 25, 2007 | 08:50 PM
torkum's Avatar
torkum
Sounds like the compressor is dragging.
Old Mar 25, 2007 | 09:38 PM
Braker 19's Avatar
Braker 19
Put new in new plugs and wires about a year ago. Could they be bad already? Wouldn't a dragging compressor have an effect on the motor going down the road?
Old Mar 25, 2007 | 11:34 PM
thehawk789's Avatar
thehawk789
it happens, AC clutches, when engaged, put a huge drain on the engine. new cars even have a WOT compressor disable function to give you full power when accelerating. It may be a bad bearing on the compressor clutch, or it may in fact be a bad compressor. hows your air filter? any other restrictions will be magnified by engine loads.
