Sponsored by: Auxito
factory 7 way plug
Old Mar 26, 2007 | 06:52 PM
seth1's Avatar
seth1
factory 7 way plug
im in the process of hooking up a brake controller and noticed the factory 7 way rv style plug has all seven wires already goin into it. so i checked the fuses to see if there was and auxilary power, etc. and there was a fuse in the spot were it needed to be, so my question is, is the truck half way wired up for the brake controller? thank you seth
Old Mar 26, 2007 | 08:13 PM
grafekie's Avatar
grafekie
If you have a factory 7 way plug your truck is ready to tow. All you have to do is mount a brake controller and plug it under the dash. No fuses, no wires, you are ready.
Old Mar 26, 2007 | 09:00 PM
seth1's Avatar
seth1
really, sweet. ya i just went out and looked under the dash and sure enough i saw the plug. then i remembered seeing some wires and a plug in a bag in my glove box and sure enough there was the other end of the plug, the relays needed and some directions. thanks for the help, i was about to start running my own wires
Old Mar 26, 2007 | 10:14 PM
grafekie's Avatar
grafekie
I didn't have the 7 way on my 1999 F150... Uhaul had me running wires too until I realized they were clueless. They did end up selling me all the wire I would have needed, which I ended up using for other purposes. If you don't have the 7 way, you only have to wire 18" under the rear bumper. But the cab side is prewired so no worries
Old Mar 27, 2007 | 10:22 PM
seth1's Avatar
seth1
k i got it all figured out, i went to hook up to the gooseneck and everything was working. then i tried the brakes and nothing. i checked my connections with a test light and everything was working. then i tested the the brake control prong on the connector and there was no power. i found out that the wire rotted away right where it enters the plug and i need to be able to extract the connector. is there any way i can do this with gettin a pin extractor or whatever kind of tool needed? thanks seth
