Found the problem!!!
Old Oct 4, 2013 | 06:44 PM
madMatador78's Avatar
madMatador78
Got the Fuel regulator in today finally. I stayed late at the shop, and will pry try and get some other projects done as well.
Special thanks to Bill (ReBilld) and Aaron (Fordman67) who without them I wouldn't have recieved a new to me regulator. Thanks again guys you rock! I seriously don't have the right words to say how truly grateful I am for your help and generosity. If you all think of it give these guys a rep!
Heres some pics of what I found when I pulled the old one out. I don't know if a guy could take and fix it some how so you could use it, cause I don't think there is anything else wrong with it.
http://www.flickr.com/photos/tombombadom/10091688786/http://www.flickr.com/photos/tombombadom/10091686046/
Also changed my fuel filter while I was in there. The PO did every oil change I thought that was a touch overbored, so I think I'll do every other maybe. Sure did look good an clean in the bowl. What do you all think of the filter?
http://www.flickr.com/photos/tombombadom/10091676856/http://www.flickr.com/photos/tombombadom/10091680376/
The new filter was one piece but this one was different, it actually came apart from the housing. I tried finding a brand but I couldnt decyfer any of the markings on it.
Only had to take the regulator back out once cause there was another o-ring on the fuel bowl (maybe that was the one that I destroyed in the kit cause I wasn't sure where it went ) but overall it was a pretty easy job to do. Looks like the rest of the bowl is tight so I'm not gonna touch it for now. Maybe down the road E-fuel will be in my future, but for now I'm gonna keep it how it is so long as its all working.
Old Oct 4, 2013 | 06:53 PM
427 fordman's Avatar
427 fordman
Glad you got it fixed Thomas. The filter looks pretty good.
Old Oct 4, 2013 | 06:56 PM
madMatador78
That is good. We were concerned a while back about some injector o-rings (which it still probably needs) but they said it could turn the filter black. So just curious. The fuel looked real clean.
Old Oct 4, 2013 | 10:34 PM
BBslider001's Avatar
BBslider001
Thomas, what was the problem again? Sorry, I don't remember. Was it idle issues? That fuel bowl looks great. I am going to tackle mine here pretty soon. I hope mine looks half that good.
Old Oct 4, 2013 | 11:15 PM
madMatador78
My regulator was leaking I couldn't see quite where. Aaron sent me one and I just finally got it in. I have the actual thread called raw fuel smell. I wasn't sure weather to add to that thread or start a new one. The idle issues I still haven't done anything with. I just changed the oil and that seemed to help some. We will see. Based on how clean my fuel bowl was my orings can't be too bad. I think I'll re do them next spring.
Old Oct 4, 2013 | 11:22 PM
madMatador78
Byron this was the original thread.
https://www.ford-trucks.com/forums/1...uel-smell.html
Old Oct 5, 2013 | 02:12 AM
stainlessstroker95's Avatar
stainlessstroker95
Glad you got it fixed. Bill and Aaron are some pretty cool dudes.
Old Oct 6, 2013 | 10:26 AM
BBslider001
Ah, yeah,now I remember! Man, that has got to feel good to get a leak fixed like that!
Old Oct 6, 2013 | 03:11 PM
madMatador78
Yeah except it's leaking again
This time around where that snap ring is on the bottom. Gonna be Pulling it out again.
Old Oct 6, 2013 | 05:20 PM
BBslider001
Nooooo!!! I want to pull my fuel bowl just to clean the valley and install the new o-rings, but I am afraid as to what will happen! It BARELY leaks now. I am afraid I will open a floodgate if I take it off of there.
Old Oct 6, 2013 | 08:47 PM
madMatador78
It would be a good learning experience. In theory it's not difficult to do, but I think like you do. Only reason I tore those apart is cause I was left with no choice.
Old Oct 6, 2013 | 11:51 PM
BBslider001
I hear ya. I have the O-Ring kit with the 3 replacement hoses from Diesel O-Rings....just hafta do it. What about draining and refilling the fuel bowl? Difficult? Does air get in the system?
Old Oct 7, 2013 | 03:01 AM
Joey Fletcher's Avatar
Joey Fletcher
madMatador
I hate to hear you still got a leak. It sucks when you think you have fixed something....then you find another issue.
When was the last time you had your fuel bowl completely off the truck. The reason I am asking last year when I change out the fuel filter it looks just like yours in the above picture....filter an all
I had no clue as to how much crap was in my fuel bowl until I removed it and started turning it every which way to drain out the fuel.
I did not remove the filter until I had it off the truck and saw all that mess running out of the fuel line ports.....I did open the yellow drain while it was on the truck.
Now that I am the official owner of the worst fuel bowl ever seen on this site.....I just want to keep it...
Good luck
Old Oct 7, 2013 | 07:41 AM
madMatador78
I have never had it off. I have only owned the truck for a couple of months. I did see your fuel bowl, that's a mess! I did however just have that regulator off and it looked clean as a whistle.
I can't remember where I heard it but someone said that it's not a matter of if you have a fuel leak but when you have a fuel leak in regards to the powerstroke.
fordman67
Oct 9, 2012 12:03 AM
jazzmaffy
May 21, 2010 10:02 PM
JRon
Apr 17, 2010 12:19 PM
pyle129
Jun 17, 2007 08:53 AM
pharmerman
Michigan Chapter
Apr 21, 2003 08:00 PM
