Connecticut Chapter Join Chapter, Leader:
300 build thread
Old Mar 31, 2011 | 08:38 PM
  #106
Zookie400's Avatar
Zookie400
i played with my brothers dui bare-handed kneeling on the radiator support. one thing to remember is that if it can shock you it will short to the engine and misfire. bigger better newer wires would be in order.
Old Apr 2, 2011 | 08:25 AM
  #107
jthorngate3's Avatar
jthorngate3
Well...I am cpr/aed certified, haha.
Old Apr 2, 2011 | 08:28 AM
  #108
Zookie400's Avatar
Zookie400
so if someone gets knocked on their **** we are golden!
Old Apr 2, 2011 | 08:32 AM
  #109
jthorngate3
Yep, Golden!
Old Apr 2, 2011 | 05:51 PM
  #110
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
.....unless it's you, Josiah, that gets 'fibrellated' by that high output ignition of yours.
Old Apr 2, 2011 | 05:53 PM
  #111
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
What carburetor "pump kit" are you talking about that you need?
Old Apr 2, 2011 | 10:19 PM
  #112
jthorngate3
I believe it is the acc. pump cams kit, they have a bunch of different colors.
Old Apr 3, 2011 | 04:16 AM
  #113
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I have a set of colored plastic cams, just like I had all those secondary springs I gave you.
Four things affect the pump shot.
1) When it comes. -Cam position relative to throttle position, which screw hole you use.
2) Cam profile. -How fast it comes on.
3) Volume. -Pump size (they come in 30 & 50cc) and lift of the cam. With your displacement and RPM's you don't need 50cc.
4) Duration. -The size of the jet(s) it's dumping through.
The same volume of fuel is going to take longer to get through a smaller shooter.
Enrichment is prolonged with a smaller jet.
Start with a rich shot and tune down to where you don't get a black cloud when you mat it. (rich may foul plugs, but it's safer than going lean, stumbling and detonating)
You also have a Powervalve in that carb, so when manifold vacuum drops below the number indicated it will richen the mixture too.
Ballpark rule of thumb; 1/2 to 1/3 of your idle vacuum. (i.e. 15"hg = 7.5 PV)
I don't know a thing about building the I-6 but what compression and cam are you using?
Old Apr 3, 2011 | 08:03 AM
  #114
jthorngate3
Stock cam, and compression is 8:1
Old Apr 3, 2011 | 05:25 PM
  #115
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
MORE POWER!
Old Apr 3, 2011 | 05:51 PM
  #116
jthorngate3
I REALLY wish I had more expendable money so I could have a lot of fun with this. Unfortunately, at this point, I just want to eliminate most or all of the rust, and get it running well, and reliable.
Old Apr 3, 2011 | 06:10 PM
  #117
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I understand, believe me, my '77 project is up on blocks.
May end up giving the F100 away before it returns to the earth.
The I-6 is supposed to be a torquey engine anyhow.
I guess it doesn't need compression???
Old Apr 3, 2011 | 06:26 PM
  #118
Towmanjbo's Avatar
Towmanjbo
What a coincidence that is what's happening to my '83 but it's going to Josiah so I guess that's ok
Old Apr 3, 2011 | 06:33 PM
  #119
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yeah Justin!
At least he got a new carb out of my need to salvage something from the project.
With my pitiful income, needing an expensive operation and a baby on the way there's no chance the 347 is ever going to happen...
Old Apr 3, 2011 | 06:35 PM
  #120
jthorngate3
A baby on the way!? And I can't thank you guys enough for everything. I really appreciate it more than you know.
