Connecticut Chapter Join Chapter, Leader:
300 build thread
Old Dec 25, 2010 | 09:54 AM
  #46
jthorngate3's Avatar
jthorngate3
Hey Bwill, good luck with the build!
Hey Greg, my buddy is interested in helping I think, but not sure timing will work, so how does friday sound?
Old Dec 25, 2010 | 05:16 PM
  #47
gbroehl1's Avatar
gbroehl1
At this point my Friday is open. Worst case I would be leaving mid - late afternoon to head to my parents, but at this point there are no plans. Plus I have no issue with you working in my garage without me here if the need should arise.
Old Dec 25, 2010 | 07:22 PM
  #48
Bwillden24's Avatar
Bwillden24
Thanks, I took today off from working on my rig
Old Dec 25, 2010 | 07:49 PM
  #49
jthorngate3
I would plan on getting started fairly early, so getting it done shouldn't be a problem.
Old Dec 25, 2010 | 09:21 PM
  #50
7.3 Rocket's Avatar
7.3 Rocket
You guys can borrow real size grease guns if needed.
Old Dec 25, 2010 | 09:43 PM
  #51
jthorngate3
Haha, thanks, but I think the little one will be adequate. Just doing a couple steering joints.
Old Dec 26, 2010 | 05:57 AM
  #52
gbroehl1's Avatar
gbroehl1
sounds like a plan.
Old Dec 26, 2010 | 07:38 AM
  #53
jthorngate3
Cool, I will need to get directions, or an address, from ya at some point before then. Should be a fun time. Have you done steering stuff before?
Old Dec 26, 2010 | 11:00 AM
  #54
gbroehl1's Avatar
gbroehl1
What kind of steering stuff? Done ball joints on a superduty recently.
Old Dec 26, 2010 | 05:18 PM
  #55
Towmanjbo's Avatar
Towmanjbo
He's doing tie rod ends and drag links, I believe. Depending on the day I might be able to come help.
Old Dec 26, 2010 | 05:19 PM
  #56
gbroehl1's Avatar
gbroehl1
Simple enough stuff as long as nothing is rusted beyond use.
Old Dec 26, 2010 | 08:05 PM
  #57
Zookie400's Avatar
Zookie400
if i recall, his truck is well lubed.
Old Dec 26, 2010 | 10:53 PM
  #58
jthorngate3
I will have a can of PB blaster with me as well. Had to do emergency surgery on my truck tonight in the blowing snow. Went to roll my window down to clean off the mirror and the window was frozen solid. Tried a little harder to roll it down and...clunk! No more window control. A few moments later, the window was falling inside the door, not attached to the window tray. Whoops! So, I tore the door panel off and put it back together.
Old Dec 26, 2010 | 11:39 PM
  #59
Towmanjbo's Avatar
Towmanjbo
Ooo I hate it when that happens! On mine the window kept coming out of the lower fixed channel, I ended up using liquid nails to affix the glass to the channel.
Old Dec 30, 2010 | 02:49 PM
  #60
jthorngate3
Well Gents, looks like it's on for the steering stuff Friday morning. I plan to get there around 8 or so. You are welcome to stop by. It's gonna be at Greg's place of residence..namely the garage. There won't be too much glitz and glamour involved, so don't expect it.
