Offroad & 4x4
thekingofcows Build Thread
Old Apr 11, 2013 | 07:52 PM
  #181
alpha/omega's Avatar
alpha/omega
Good answer.
Old Mar 2, 2014 | 07:32 PM
  #182
thekingofcows's Avatar
thekingofcows
Been a while since a posted an update on my truck. I've nearly worn the hawgs out, the lugs are starting pop off, so I'll be in the market soon for new tires.
I pulled my tranny last weekend to fix a leak and decided to go through it and found this...
I don't really know how it was working so well with the low reverse clutches completely gone. I guess the manual valve body really throws some pressure to it.
I'm also in the process of upgrading to hydroboost. I got a unit off like 2008 model f250, and made a conversion bracket for it.
Since I wanted to keep it all low profile, I didn't extend the bracket off the firewall like the original. The booster rod is now too long to bolt to the brake pedal, plus my brake pedal is the one with the weird offset, so I guess rather shortening the rod, I may just weld a bracket to the brake pedal to make up the difference. Maybe this pic will explain it better.
I guess that's about it. Any input is welcome.
Old Mar 3, 2014 | 04:36 PM
  #183
77mud's Avatar
77mud
What tires you looking for next?
Old Mar 3, 2014 | 05:21 PM
  #184
thekingofcows
44" boggers. But I might could settle for swampers.
Old Mar 3, 2014 | 11:12 PM
  #185
73 ford guy's Avatar
73 ford guy
I like the plate mount for hydroboost. I always reccomend doing it that way for easy install but I just weld plate to firewall.
For rod being too long I cut and full pen welded. Do it if your capable. Here's a couple saved pics I had on this issue.
Couple ways you could go.
Top pic: if rods are same diameter. Slide on sleeve, bevel, weld , grind weld smooth, slide sleeve over weld, weld sleeve.
Bottom one is if your welding two different diameter rods.
It has to be good!! It's the most important weld on your rig
Old Mar 3, 2014 | 11:25 PM
  #186
thekingofcows
^^^ I thought about shortening the rod, but I would still have to pull the pedal and re-drill the mounting hole. I've thought about just cutting the push rod, threading it, and building an L shaped bracket to drop the push-rod down the inch or so to the brake pedal hole.
The other option would be to pull the brake pedal and weld a bracket to the pedal that would extended toward the rear of the truck and mate with the stock length push rod. If I did this, however, I would need to shim the brake pedal to the side about an eighth of an inch to clear the wider part of the push rod.
In Hindsight, I should have taken more time and built a bracket that offset the booster the correct difference from the wall, then I could use a stock booster with no modifications... sometimes laziness trumps good engineering though.
I didn't weld the plate to the firewall simply because I have a bunch of dampening material in that area, and it would be a mess to remove. Furthermore, I wanted to retain those four bolts as they hold the brake pedal assembly.
Old Mar 6, 2014 | 12:01 PM
  #187
dixie460's Avatar
dixie460
Hey kingofcows, just stopped by the 4x4 forum and saw your build... nice work!
Love them dentside trucks. Hell any Ford covered in mud looks good...
Old Mar 11, 2014 | 03:10 PM
  #188
JoeyGowdy's Avatar
JoeyGowdy
If I had know sooner I would have given you my old 44s...
they had like 50% left on them... just put 50s on my rig.
Old Sep 16, 2014 | 07:08 PM
  #189
thekingofcows
Head Gasket...
Tires
Old Sep 16, 2014 | 07:23 PM
  #190
77mud's Avatar
77mud
With those 44" boggers you'll find your weak links.
martin72
146
Sep 22, 2017 11:01 AM
thekingofcows
16
Jun 25, 2015 08:33 PM
martin72
18
May 22, 2014 07:51 PM
thekingofcows
Offroad & 4x4
28
Dec 24, 2012 02:49 AM
thekingofcows
24
Mar 29, 2012 09:53 PM
