Minnesota Chapter Join Chapter, Leader: fordpower88
Almost spring (march) B.S. thread
Old Mar 8, 2010 | 07:50 PM
  #196
fordpower88's Avatar
fordpower88
Doin good David. Just hangin out at home with my son, wife is at her book club tonight. How was your day?
Old Mar 8, 2010 | 07:52 PM
  #197
dlibson's Avatar
dlibson
Not to bad Troy, thanks!
A bit gloomy today. We've been a bit spoiled I guess.
Old Mar 8, 2010 | 07:57 PM
  #198
fordpower88
Yeah we have been spoiled for sure! Sounds like it is going to be gloomy all week out here anyway. Getting any farther on your rear seat mod?
Old Mar 8, 2010 | 07:59 PM
  #199
dlibson's Avatar
dlibson
Not so far. I got some of the stuff I need and laid out a plan. Gotta do some modification to the seat mount points. I want to make it easy to do for others if they want to follow...
Not sure how yet!
Old Mar 8, 2010 | 08:03 PM
  #200
fordpower88
The planning part can take longer than the actual building part. So did you do all the work on your ranger getting that v8 stuck in there?
Old Mar 8, 2010 | 08:08 PM
  #201
dlibson's Avatar
dlibson
Yes I did. Ground up job...
It was good times!
Old Mar 8, 2010 | 08:12 PM
  #202
fordpower88
I bet you know this was coming...got any pics? I bet that is one quick son of gun! How long ago did ya build it?
Old Mar 8, 2010 | 08:16 PM
  #203
allis327's Avatar
allis327
Evening everyone we are flying through the pages on this forum. Can't wait for the next gtg to meet everyone.
Old Mar 8, 2010 | 08:20 PM
  #204
fordpower88
Evening Mike, have you checked out the camping gtg thread? You should try and make it.
Old Mar 8, 2010 | 08:53 PM
  #205
dlibson's Avatar
dlibson
Sorry for the delay....
I do have some pics. I'll post 'em up. I built it about three years ago. Well, finished it...
Old Mar 8, 2010 | 08:58 PM
  #206
fordpower88
No problem on the delay if your like me I got about 8 tabs open checking everything out. Looking forward to the pics!
Old Mar 8, 2010 | 09:00 PM
  #207
dlibson's Avatar
dlibson
  #208
dlibson's Avatar
dlibson
Here are some of the early pics and parts I've did already. Including mounts.
I will be making my own headers. The steering will remain factory. I had to make no modifications to the frame, firewall or anything. (I did bend the seam on the firewall for ease). I used a factory ford f150 2wd mount for the passenger side and made a cradle on the frame for it. On the drivers side I made a custom mount to mate the block to the factory ranger mount. After my first trial fit. I raised the motor an inch, and to the passenger side about 3/4 of an inch for clearance reasons. I will make a new mount on the drivers side eventually. I used the factory Crown Vic tranny crossmember and just shortened it and bolted it to the frame.
Like I said. After I have this running, I will perfect the mounts, and other parts. I will make kits to install SOHC's in the 80's era Rangers. I am moking my own headers, the are going to run out side the frame, then I will put a collector and run side pipes. So the frame, and steering are not issues. Thanks for the support so far guys!
Old Mar 8, 2010 | 09:02 PM
  #209
dlibson's Avatar
dlibson
The Air Intake a simple job, especially with all the others.
A look at the belt, all we did here was eliminate the A/C and route the belt differently.
Here is a look at the steering shaft, it ended up being a straight shot. As previously stated, I used a Nissan pickup setup to mount outside the frame. I simply installed the Ranger outers into the Nissan inners.
Okay the next few are of the headers, from test fit looks to pics of the final product.
Old Mar 8, 2010 | 09:03 PM
  #210
dlibson's Avatar
dlibson
first is a belt pic. NO A/C so a different route, and smaller belt.
Here is a pic of the Nissan steering box, lines hooked up. Just compression fitted the Ford line to the Nissan line.
Here are pics of the Drivers side exhaust. I saw a few Rangers with side pipes, decieded I didn't like it. So instead some 3" pipe and Flowmasters!
Here is the passenger side!
Here are a couple shots of the truck! It is a convertible. I bought it that way. I am making a hard top for it.
