What Have YOU Done To Your Truck Today?
  #10681
Old 03-22-2021, 03:45 PM
Meridian_Mike's Avatar
Meridian_Mike
Meridian_Mike is offline
Originally Posted by SlikWillie
Tell your bother "Good job!" and then tell him to become a member because we want to see more of that truck.
For sure!!!!
  #10682
Old 03-27-2021, 04:20 PM
SlikWillie's Avatar
SlikWillie
SlikWillie is online now
Scored a right side exhaust manifold from the local salvage yard. It was in a huge pile of manifolds. Didn't think I would find one, but I got lucky today.
  #10683
Old 03-28-2021, 08:16 AM
black & blue 78/9's Avatar
black & blue 78/9
black & blue 78/9 is offline
Seals
Yestetday, I changed the steering gear input and sector shaft seals. Was not to bad. Between the type F leaking for months, the pitman arm came off easily.. Unbolted easy. It is heavy and helps to remove the power steering pump and ps return line out of the way. I used the threads here to do the seals. Great idea to use screws to pull the seal. Took way to long to clean the outside of the steering gear housing and alot longer to degrease the inside/outside of the frame. The tubes inside the frame for the gear mount were packed with crud and dirt. So I cleaned those out so as to not fill the threads with dirt when installing the bolts.
I still need to bleed the system, torque the pitman arm and reconnect the steering shaft to the gear box and column to dash. Then hopefully enjoy and leak free truck. Of course until the next item starts to leak.
  #10684
Old 03-28-2021, 09:25 AM
kwbpics's Avatar
kwbpics
kwbpics is offline
Angry
Pulled the handle to drain the fuel/water separator. Nightmare. She won`t close and fuel everywhere. The cable was stuck so I pulled a bit more - now the cable has come off it1s mooring.
Does anyone know where to get a new cable for this 2002 E450? not at rockauto.
close up cable to water drain, 2002 E450 ambulance. (stuck open).
  #10685
Old 03-28-2021, 09:37 AM
redroad's Avatar
redroad
redroad is offline
You'll have better luck posing you're question here to get an answer https://www.ford-trucks.com/forums/forum128/
  #10686
Old 04-04-2021, 07:22 AM
Colemater's Avatar
Colemater
Colemater is offline
Interior
This past weekend I finished most of the interior and cleaned the old girl up
last weekend new windshield and back window
see for yourself!
Still working on seat belts
  #10687
Old 04-04-2021, 08:06 AM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Received 3,358 Likes on 2,496 Posts
Looking good, and it looks like you are still waiting on that xfer case trim ring? So you do have the upper cab corner seat belt covers? Uou know you can use the Rite Dye trick on the seat belts.
  #10688
Old 04-04-2021, 08:52 AM
Colemater's Avatar
Colemater
I have the covers but I stripped one of the bolts
friend of mine owns a gas station and garage - hope he can get unstripped
still waiting on trim ring
what is the Rite Dye trick?
  #10689
Old 04-04-2021, 11:43 AM
77&79F250's Avatar
77&79F250
Basically this...
Just pull the belt all the way out (to the stopping point of the reel) and us a gator or simular clip/clamp to hold it out and follow the directions on the Rite Dye bottle and have at it. Do not dunk the retraction reel.
  #10690
Old 04-08-2021, 04:29 AM
Henk de Boer's Avatar
Henk de Boer
Henk de Boer is offline
Hi guys,
I'm looking on this forum for an answer to a couple of questions. Very cool to see everything that's been done on your trucks to keep them on the road.
I got my first pickup. It a F150 Custom Supercap 1977 with side mounted rear seats in blue. I'm looking to get a forward facing folding rear bench and other stuff
1. Where can I get a rear bench from? (I'm living in the Netherlands)
2. Looking for a sidetrim horizontally between the indicators
3. Can I build in cruise control, AC and power steering?
Thanks for your reply!
  #10691
Old 04-08-2021, 07:18 AM
77&79F250's Avatar
77&79F250
Well with you in the Netherlands that is going to probably an expansive upgrade due to the size of what need to be mailed to you. If you was stateside I am sure someone has one or knows of one somewhere. I actually have the two panels, meaning the seat part and the back that folds down. But no foam of vinyl cover.
Side trim between the indicators? You mean the side trim that goes from the front and to the rear side marker lights? Meaning the chrome looking trim with the black stripe AKA the "dent trim"? Repop vendors sell it.
And remember you need it WITHOUT race trac trim. Unless you want to add that trim on also? FYI if you do not have the dent trim mount "button like rivet heads" already there, they used put the plastic mount piece to mount the trim to, you are in for some work.
This is what it takes, white plastic and metal pieces and a rivet gun. And possibly separate metal retaining pieces are used around the side marker lights. Hole drilling time.
https://shop.broncograveyard.com/197...uctinfo/25170/
https://www.dennis-carpenter.com/tru...r-molding-rh-8
https://www.dennis-carpenter.com/tru...pper-mldg-lh-8
JBG https://shop.broncograveyard.com/Bod.../products/133/
https://cgfordparts.com/wwwsectionfi...ding_sets.html
https://www.lmctruck.com/1973-79-for...r-side-molding
Cruise...tall order to get all the parts, you might be looking into aftermarket CC.
Same for a/c like from classicairauto.com
https://www.restomodair.com/1973-197...ditioning-kit/
https://www.fatfendergarage.com/product/1973-1979-ford-truck-a-c-kit/
https://www.fuelcurve.com/vintage-ai...00-and-bronco/
https://nostalgicac.com/complete-ac-kits/ford-complete-kits/ford-ac-kits-for-trucks/73-79-ford-truck.html
At least p/s in a kit form is out there on the web. Here is what it takes to mount the trim to a fender.
  #10692
Old 04-08-2021, 08:25 AM
NM76F150's Avatar
NM76F150
NM76F150 is online now
see for yourself!
Beautiful truck and I love that high quality tach mount.
  #10693
Old 04-08-2021, 03:59 PM
Henk de Boer
Beautiful truck! I hav the same colour! Is it also a Custom?
I've added a picture of the sidetrim - dent trim. This is what I need and miss....
  #10694
Old 04-08-2021, 04:07 PM
Henk de Boer
Thumbs up
https://www.fatfendergarage.com/prod...truck-a-c-kit/
https://nostalgicac.com/complete-ac-...ord-truck.html
Thanx man! This is indeed what I need.
I will check your URL's to get it. I think the truck will become much nicer. hopefully I also can get it in the Netherlands. Hereby a picture of my light blue Custom Supercab
  #10695
Old 04-08-2021, 09:15 PM
SlikWillie's Avatar
SlikWillie
Yesterday I cut out the old rusty exhaust pipe and removed headers. This morning I installed my old exhaust manifolds and started cutting, welding, and fabbing up my fresh exhaust with a Flowmaster muffler.
It got a little messy using flux core wire in my mig. But, no leaks and she's all solid.
Quick Reply: What Have YOU Done To Your Truck Today?
