Calibration Code to to EEC Program Code
Old Jul 20, 2025 | 01:15 PM
  #136
DPDISXR4Ti's Avatar
DPDISXR4Ti
Interesting that Upfix calls them transistors instead of capacitors. I can see from the photos that it's the capacitors that they have replaced.
Old Jul 20, 2025 | 03:25 PM
  #137
subford's Avatar
subford
If you smell fuel while cranking the PIP is more than likely working.
Unplug the computer to stop the injectors from firing while you work on the spark problem.
Old Aug 7, 2025 | 04:25 PM
  #138
J913093's Avatar
J913093
2nd Gear
Hello,
I have not been able to make your links work. I am trying to get the correct ECM for my 1989 F350 rear wheel drive dually with 5sp manual transmission. Motocraft does not recognize the VIN. (2FTJW35G4KCB23368). Here is the calibration code from the door.8-97A-R10. Any help or advice would be much appreciated.
Old Aug 8, 2025 | 08:42 AM
  #139
subford's Avatar
subford
Calibration code 8-97A-R10 translates to part list No 54.
Parts list No 54 gives FORD part No F0TZ 12A650-AXA and the No on the unit F0TF 12A 650-AX1A.
Old Aug 8, 2025 | 10:33 AM
  #140
J913093's Avatar
J913093
2nd Gear
Thank you, I have been fighting with this for a while. The dealer has been no help.
Old Sep 30, 2025 | 03:10 PM
  #141
alanazon's Avatar
alanazon
Hello, wondering if you have a calibration parts list for 6-98Q-R10.
Looks like the previous links no longer work. Thank you!
Old Sep 30, 2025 | 03:44 PM
  #142
subford's Avatar
subford
Sure here it is:
Old Oct 1, 2025 | 07:47 AM
  #143
alanazon's Avatar
alanazon
Thank you so much!
It's been difficult to confirm part numbers for this truck. The shop manual can be a bit ambiguous for the 1996 California F250s over 8500 GVWR.
Old Nov 2, 2025 | 01:03 PM
  #144
toadswrecker's Avatar
toadswrecker
2nd Gear
ECM interchange?
Subford, can you help? I need a replacement ECM for my 1996 F350 4x4 MT. The original ECM is a F6TF-12A650-BFA and apparently they are rare I assume. I cannot find anything less than $1200. My question is can I use another ECM with a different calibration code? If so would you know what would be compatible?
Old Nov 2, 2025 | 03:15 PM
  #145
AuroraGirl's Avatar
AuroraGirl
is this an eec-iv truck(not california MAF)
If so, you need a PCM for a v8 with MAP sensor and a manual transmission, the pcm has to be a 8 cylinder or it wont run the fuel injectors right (i6), it has to be manual transmission / c6 computer so it doesnt try and operate a transmission
That would probably work but youd want to have a 7.5 for fuel maps id think to be best accurate. otherwise aftermarket J3 port tuning can be done (moates for example)
IF this is eec-v, then any 8 cylinder pcm should be able to be flashed by a dealer to the proper calibration even if its different part number .
Old Nov 2, 2025 | 03:49 PM
  #146
toadswrecker
2nd Gear
Yes, it is an eec-IV with map sensor. The only two ecm’s I can find on rockauto are calibration #’s 6-98P and 6-98T. My cal # is 6-97A. I’m just trying to figure out what would work with my powertrain other than my current inoperable
6-97A.
Old Dec 21, 2025 | 08:19 PM
  #147
Bubbasuwannee's Avatar
Bubbasuwannee
2nd Gear
Would it be possible to get the calibration code for the following? It’s a 1996 F-150 XLT 4.9L 2WD 5-speed built in December 1995
Old Dec 21, 2025 | 09:43 PM
  #148
cougrrcj's Avatar
cougrrcj
That's the same 'Authorized Modification' sticker I had on my long-gone '87 Crown Vic Police 351. Originally a Variable Venturi '2-barrel', there was a 'quiet' Ford-authorized TSB for police to get retrofitted with the mid-80s truck 351HO 4-barrel intake and carburetor. BUT, from what I have learned is that those modified cars were never to be sold to the public afterwards. Oops. Mine slipped trough... I bought it at the municipal auction in 1991 with 111k miles. I sold it to a buddy in 1994. He later yanked the motor and rebuilt it for his '88 T-bird race car.
Old Dec 22, 2025 | 12:35 AM
  #149
AuroraGirl's Avatar
AuroraGirl
Old Dec 22, 2025 | 06:59 AM
  #150
Bubbasuwannee
2nd Gear
Originally Posted by AuroraGirl
thanks so much!
CamoF-250
May 31, 2019 10:23 AM
Homerunking2394
6.2L V8
Aug 20, 2016 01:50 PM
oldbird1965
Dec 11, 2010 11:00 PM
rcd771
Dec 10, 2004 06:54 PM
Turbo_Whistler
Sep 18, 2004 07:47 PM
