Offroad & 4x4
Cheetos Crew Build
Old Aug 14, 2010 | 09:07 PM
  #466
66crawler's Avatar
66crawler
you guys do know that shocks work the best mounted vertically right?
Old Aug 14, 2010 | 09:11 PM
  #467
crazyredneckanyhow's Avatar
crazyredneckanyhow
Ok then you explain to me how im supposed to mount shocks with 12" of travel vertically and still have a usuable bed and not loose ground clearence.
Old Aug 14, 2010 | 09:16 PM
  #468
alpha/omega's Avatar
alpha/omega
with a 1" body lift your bed (because the tool box wont hit the hanger anymore) will bolt securely to the frame and will also level the cab/front clip up in line.
I guess I dont understand how the hitch will hit the bed sides.
Old Aug 14, 2010 | 09:20 PM
  #469
crazyredneckanyhow
Ok You know how a gooseneck hitch works and when you turn your bed goes under the tongue. Well my truck is way to damn high for that to work without a custom made trailer tongue
Old Aug 14, 2010 | 09:27 PM
  #470
crazyredneckanyhow
Lika dees.
A normal trailer wil not fit over bedsides as high as mine.
  #471
alpha/omega
What you shouldve said was the gooseneck of the trailer would hit the bedsides and not the hitch :flipoff:
btw...
Thats to be expected with 37" tires there highspeed.
PS...
thats exactly what Im looking for in a trailer except the dual wheels. Im only looking for a 4-5 ton rated trailer and something in the 24'+ dovetail range. Find me one with your Cheet-hoe powers.
Old Aug 14, 2010 | 09:33 PM
  #472
crazyredneckanyhow
Not really. The guy that bought my last bronco has a SD on 37s and his clears.
BTW im gonna cut the toolbox liner and attach a piece of lexan with teh wondshield adhesive. Also somehow i managed to get the pass side WB off by 1.5". Apparently all the factory bolts holes are not the smae on each side.
Note to self: Measure from the end of the frame from now on.
Old Aug 16, 2010 | 11:32 AM
  #473
ChaseTruck754's Avatar
ChaseTruck754
Did you fix the shock mounts or leave them like in the pic?
Almost done...
Old Aug 16, 2010 | 05:03 PM
  #474
crazyredneckanyhow
Im makin the shock mount a crossmember.
Old Aug 17, 2010 | 01:59 AM
  #475
ChaseTruck754
you feeling rich redneck????
Cuz I got a box of parts that can now be sent your way...
Old Aug 17, 2010 | 06:52 AM
  #476
fordtrucknut's Avatar
fordtrucknut
Damn Steve!!...those are good looking!!!
Old Aug 17, 2010 | 11:05 AM
  #477
ChaseTruck754
Yup. pretty much copies of mine.
Old Aug 17, 2010 | 12:22 PM
  #478
scottfreeman's Avatar
scottfreeman
Nice
Originally Posted by ChaseTruck754
Cummins swap mounts?
Old Aug 17, 2010 | 02:40 PM
  #479
ChaseTruck754
yup........
Old Aug 31, 2010 | 08:29 PM
  #480
crazyredneckanyhow
Ugh. This thing is kickin my ***. I just dont know about it anymore. Still have to complete a ****ton of frame mods. Bed needs a new floor to fit the narrow frame. Then rebuild the rears/tranny/tcase. Run brake/fuel lines. Interior and paint. I just dont know about it anymore. Noones fault but my own. I jumped into this to quick and its just gettin the best of me. I just want to drive the damn thing but it looks to be another 2 yrs before that will happen. Im also running out of cash quickly.
