They look purdy and beefy, but the spring adjustment threads don't look to be all that deep. Also is there a lock nut to keep the nut in its place so it doesn't unthread on you? I guess if they are designed to handle the stress, they should be good to go. Hurry up and get this thing done so we can hear the 300 roar.......
They look purdy and beefy, but the spring adjustment threads don't look to be all that deep. Also is there a lock nut to keep the nut in its place so it doesn't unthread on you?.......
yes their is one......threads are pretty deep....
I dont think it will be as bad as you might think. The low end power of a 300 with the 6.71 gearing of the rocks things might get interesting. He'll deffinately be able to keep the tires turning and will do a better job at it than say a 302 or mild 351W would.
if I could easily and efficiently get 600+ hp out of one while still having the manerisms of a 300 (peak hp at 3500rpm peak torque at 2000rpm wont die even if the water pump fails type thing) I wouldve built one for george. I love those motors.
