Offroad & 4x4
quadzjr's build thread!!!
Old May 22, 2008 | 10:34 PM
  #511
quadzjr's Avatar
quadzjr
just another Rockwell looser
Originally Posted by RawPower
haha I was just kidding... def put a bend in your high steer arm
those coils are friggin sweet/uber-bling
i know....
thanks!
Old May 22, 2008 | 11:33 PM
  #512
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
looks good nick... and those are some super beef jack stands... Bling Blingin on the coils are we? Looks good!
Old May 29, 2008 | 07:04 PM
  #513
quadzjr's Avatar
quadzjr
dreaming of 4linking the rear too...
transfer case mount: had teh welder to cold......i had to grind it off and weld again....
welding:
bottom transfer case mount.....you can see where i couldn't reach with the welder good:
side transfer case mount......i found out i couldn't fit a bolt between the tcase and the "diaper" so i just welded it on:
Old May 29, 2008 | 07:11 PM
  #514
ibleedblue1385's Avatar
ibleedblue1385
nice work. how far from being done are you thinking?
Old May 29, 2008 | 07:18 PM
  #515
quadzjr's Avatar
quadzjr
there is prob. more......i made it at 7am......
measure for tie-rod, Cut DOM and weld in tubing inserts, install Tie-Rod
Buy Coilovers and install, weld in top mounts, may need to trim bottom hole out
Measure for draglink, Cut DOM and weld in tubing inserts, install draglink
Design brackets (upper and lower) for panhard at the same angle as the draglink, and have them cut out.
Install brackets and weld in. Measure for panhard, Cut DOM and weld in tubing inserts, install panhard.
assemble front axle
Fix gas line
clean and paint frame, sub-frame, links, etc
install rear axle
buy shackles
Design front & rear hangers and have them cut out, weld hangers together….
get desired shackle angle before welding frame to mount hangers
Measure for drive shafts and get them made, install drive shafts
Measure for brake lines, get lines made, install brake lines.
Get and install bumper back from friend
If there is time before mudfest (doubtful)
Buy 1.75”x9” ram from psc (have email of price)
Buy hydraulic lines and fittings.
Remove old steering box and install new hydro assist one, swap pitman arm over.
make mounts on axle and draglink for hydro ram, install ram and hydro lines.
purge lines with PS fluid
Test drive truck, get all quirks out.
Old May 29, 2008 | 07:41 PM
  #516
rbloodhound's Avatar
rbloodhound
Nick keep up the good work. I can't wait to see this beast finished.
Old May 29, 2008 | 07:42 PM
  #517
STGFordCrazy04's Avatar
STGFordCrazy04
Looks great Nick. Im especially diggin' the Tcase mounts
Old May 29, 2008 | 07:46 PM
  #518
quadzjr's Avatar
quadzjr
me neither.......it will be great day
thanks......got some good welds on most of them.....
Old May 29, 2008 | 08:20 PM
  #519
Truckin4life
looks good nick... Welds look go too.
In all reality thats not to bad of a list... But im sure it will take some time with school... When is that over with?
Still paitently waiting for a final product... Getting a little more impatient though
so....
HURRY IT UP!!!!
Old May 29, 2008 | 09:04 PM
  #520
quadzjr's Avatar
quadzjr
so....
HURRY IT UP!!!!
im taking the summer off school, so i work full time then work on it just about everyday for a hour or two after work......then a full day on the weekend...
Old May 30, 2008 | 08:15 PM
  #521
Truckin4life
good stuff... Wish i had the time and the place for a project like that...
Old May 30, 2008 | 08:26 PM
  #522
quadzjr's Avatar
quadzjr
time, well all you need is another vehicle for a dd and you have all the time in the world to build a truck......and place, well, you see where im working....in the driveway......
Old May 30, 2008 | 08:35 PM
  #523
Truckin4life
very true... actually ive seen what i belive to be an early 80's late 70's bronco sitting by a house for about a year now... so i will see if i can get him to sell it to me and throw the 429 and c6 out of the race car into it... should be good... i also saw a set of rocks for sale here 1k for the set... gets me to thinking....
Old Jun 2, 2008 | 08:27 PM
  #524
quadzjr's Avatar
quadzjr
coilovers shipped out today!!!!
OOOOOOOOOOOHH GIGGITY!!!!
Old Jun 2, 2008 | 08:39 PM
  #525
STGFordCrazy04
now if you only had some "real" axles to bolt them to.
All you need is a SD D60 and 10.5 rear.
