Offroad & 4x4
quadzjr's build thread!!!
Old Jun 3, 2008 | 11:39 PM
  #541
RawPower's Avatar
RawPower
To be honest, I'd redo the lower link tabs. I'd make the plate larger, so that it serves as a tab and as a gusset for the center bar. As for joint @ the frame where the two center pieces of tube meet I'd make a large plate that goes up the side of the frame about 2" and down below the frame about 3 or 4", then cut some 3/8" slits in it that run along the center of the tubes, then burn in those gaps w/ weld to the tubes.
Does that make sense?
Old Jun 4, 2008 | 04:44 PM
  #542
Slow's Avatar
Slow
I think your front to rear strength will be fine, I'd triangulate accross the middle for side loads.
Old Jun 4, 2008 | 05:15 PM
  #543
quadzjr's Avatar
quadzjr
just another Rockwell looser
Originally Posted by kjett
There is a tube that ties the 2 sides of the subframe in the front, are you going to add another tube toward the back as well? It looks tight with the t-case diaper, but it should fit, that way it will give strength to the rear for when you do the back part of the truck.
its already done.....check out the tcase mount pics.....they are all gusseted
Old Jun 4, 2008 | 05:16 PM
  #544
quadzjr's Avatar
quadzjr
Originally Posted by IB Adrian
How bout a small bar where I put the yellow line, and don't worry about the gusset I tried to black out (but got lazy).
I assume the other 4-link is going to be mounted on the sub-frame in the same manner?
If so, do the small bars on the same at the other end too
ya know......i planned on that, but for some reason i never got around to it......thats what i did on my buddies truck...
Old Jun 4, 2008 | 05:18 PM
  #545
quadzjr's Avatar
quadzjr
nope......i got redo lower link tabs.....thats about it.....
Old Jun 4, 2008 | 08:36 PM
  #546
RawPower's Avatar
RawPower
well that was right, I'd definitely redo the lower link tabs for more strength
Here is what I would do.
green = plate steel
red = where you cut gaps and fill in w/ weld to help w/ structure
Old Jun 4, 2008 | 08:54 PM
  #547
quadzjr's Avatar
quadzjr
green = plate steel
besides the tab strengthening part, whats the point of the bigger ones on the frame.....the tabs i designed would do the exact same thing, only look better in the middle of the tube.....boxing the inside points on the frame at those points would be more beneficial strength wise more then any other part.......especially the frame esentially makes it single shear......
im thinking of boxing in the bottom part of the tabs.....
Old Jun 8, 2008 | 03:36 PM
  #548
quadzjr's Avatar
quadzjr
my latest trip to skyhighpeformance (precision plasma)
all my parts for my rear hangers, perches, and some gussets.....
this is what the hangers will look like.....
Old Jun 8, 2008 | 03:39 PM
  #549
ibleedblue1385's Avatar
ibleedblue1385
AWESOME!!! good looking stuff there...
Old Jun 8, 2008 | 03:53 PM
  #550
captain p4's Avatar
captain p4
noice
you aint put it on yet? what you waitin for?
Old Jun 8, 2008 | 04:16 PM
  #551
RawPower's Avatar
RawPower
x2
now weld it up (pics yo)
Old Jun 8, 2008 | 07:30 PM
  #552
quadzjr's Avatar
quadzjr
im working on it all next week......i should have the rear end in....
Old Jun 8, 2008 | 07:53 PM
  #553
crazyredneckanyhow's Avatar
crazyredneckanyhow
Im diggin those lift blocks
Old Jun 8, 2008 | 08:08 PM
  #554
quadzjr's Avatar
quadzjr
only 3"......i didn't want to make my hangers bigger then they all ready are.....and they are welded to the axle...
Old Jun 8, 2008 | 08:16 PM
  #555
STGFordCrazy04's Avatar
STGFordCrazy04
you never cease to amaze me. Damn that looks beef.
Im drunk now so Ill comment more later.
