I've seen a dual clamp setup that holds hoses side by side. a few of them and a couple of zip ties to keep the small brake line with the larger hyd lines would work. Most places that make up hyd lines also have the abrasion resistant sleeving that you might be avle to fit it all into.
Edit: something like this with a few zit ties to keep it all togehter would work:
what is somthing i could use to hold all the **** going down to my axle together (brake lines, hydro lines, axle vents, speed sensor wire, etc) and kinda protect it w/o trapping mud in at the same time?
Well, it's kind of rare and expensive, but you might want to try these things out...
I use the velco version for work. It's great because you can open it up to add another cable, or do repairs. So in your case, you can remove it for clean up and then put it all back together for the next run.
lol.....you may be right.....fishing has sucked recently, thats why i have been working on it.....when it warms up some, i'll be back on the water instead of working.
so you made some progress, gonna actual finish this thread so random people quit asking "what ever happened to that quadzjr guy? his thread was cool, but what happened to the truck?"
