what if you boxed in the triangle made in the center of your subframe like one big gusset? a cool design or something. Otherwise Id consider doing it like this.
i dont want to fill in that whole thing, one, it dont need that much strength, its already pretty beef, 2, it would be very heavy, and 3, right now (till i put in my 460/c6) im shifting my tcases by hand, i know, lame, but thats what i decided on for now, after that im doing linear actuators....
im going to see what it looks like with those gusseted, thanks
i think this is kinda too much, and looks a little weird with the front peice missing.....and would be pretty expensive b/c these are all 3/8" steel...
There is a tube that ties the 2 sides of the subframe in the front, are you going to add another tube toward the back as well? It looks tight with the t-case diaper, but it should fit, that way it will give strength to the rear for when you do the back part of the truck.
