Offroad & 4x4
quadzjr's build thread!!!
Old Feb 28, 2010 | 11:13 AM
  #646
alpha/omega's Avatar
alpha/omega
as long as youve been working on it Im surprised Egyptians didnt carve the first couple pages into pyramids.
Old Feb 28, 2010 | 11:38 AM
  #647
ibleedblue1385's Avatar
ibleedblue1385
Soooo true.
Old Feb 28, 2010 | 04:41 PM
  #648
quadzjr's Avatar
quadzjr
just another Rockwell looser
lol....im a slacker
Old Feb 28, 2010 | 06:46 PM
  #649
68shortbed's Avatar
68shortbed
I just read all 43 pages yesterday. You need to get on the ball and get that truck finished man. I'm a slacker myself with my projects, but reading all this has got me inspired. when i get over this cold i'll be out in my shop workin on my trucks every chance i get. keep up the good work man.
Old Mar 1, 2010 | 07:30 AM
  #650
Broncoholic1's Avatar
Broncoholic1
Originally Posted by quadzjr
i dont have a build thread anymore, besides this one......i'm over it.
Over with the build?
Take a sh**tty cell phone pict at least
Old Mar 1, 2010 | 09:24 AM
  #651
quadzjr's Avatar
quadzjr
lol.....i still have a old chitty nextel w/o a camera built in....
most recent pics are in a different thread.
i'll try to get some this coming weekend
Old Mar 3, 2010 | 09:03 PM
  #652
quadzjr's Avatar
quadzjr
just bought gear oil for my truck......a 5 gallon bucket full......that should last all of 1 fill up!
anyone know of any good DOT approved custom brakeline maker?
Old Mar 3, 2010 | 09:18 PM
  #653
kjett's Avatar
kjett
Brakeline? You want hard lines or flexible lines? Wilwood and Earls are a couple.
Old Mar 3, 2010 | 09:25 PM
  #654
quadzjr's Avatar
quadzjr
flexable lines down from the frame to the axle......they need to be long....
Old Mar 3, 2010 | 09:28 PM
  #655
kjett's Avatar
kjett
Contact Earls, I'm sure they can make you something. You jsut need to know the fittings on each end and the length.
Old Mar 3, 2010 | 09:29 PM
  #656
quadzjr's Avatar
quadzjr
im gonna run hard lines to the center of crossmember under engine, the flex lines down to the axle then hard lines to before knuckle the flex to the calipers
same for the rear except only one flex line dropping down.
i also need to find the little weld on tabs i can use to hold the line in place that hooks to the connections if anyone knows what im talking about
what size brakelines should i use?
Old Mar 3, 2010 | 09:38 PM
  #657
kjett's Avatar
kjett
If you make up something like a late 70's deal, they use a single in the front and a single to the rear with t-taps to the wheels. As for the size, what are you using for the hard line? They should be able to match what you need. Just talk with them and tell them what you are doing. A good stainless braided hose would serve your needs well.
Old Mar 3, 2010 | 09:44 PM
  #658
quadzjr's Avatar
quadzjr
so i should just tee the existing hardline into one flex line going down for the front?
why did they stop doing this?
no clue on size.....i know nothign about brakes, running the stock M.S.
i'll talk to them
Old Mar 3, 2010 | 09:54 PM
  #659
kjett's Avatar
kjett
Yeah, when they switched to TTB on the 1/2 tons, the changed from a single flext line from the frame to the axle to 2 flex lines from the coil buckets to the knuckle. Don't know why, it seems more in the way to me. So when I did my SAS on my 95, I went the old style way. Since you need the rediculously long line, not sure what would be best for your application.
Old Mar 5, 2010 | 09:18 PM
  #660
quadzjr's Avatar
quadzjr
what is somthing i could use to hold all the **** going down to my axle together (brake lines, hydro lines, axle vents, speed sensor wire, etc) and kinda protect it w/o trapping mud in at the same time?
