2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Transmission Problems?
Old Aug 23, 2007 | 10:50 AM
  #61
berry1234's Avatar
berry1234
Any updates?
Old Aug 23, 2007 | 11:32 AM
  #62
carbonmetallic's Avatar
carbonmetallic
going in this afternoon to pick it up, lets keep our fingers crossed it works correctly. I'll try and scan in the invoice for work performed.
Old Aug 23, 2007 | 02:27 PM
  #63
carbonmetallic
Picked the truck up, seems transmission is FIXED, it shifts smoother than it ever has. Seems like this solved them problem, but only time will tell. I sped up slowed down and you cannot feel the truck shifting gears, so smooth, but if you watch the rpm's you can clearly tell it is shifting where it should be.
Quoting off of invoice received for work performed:
Update transmission adaptive strategy, ran eec test p1000, ran oasis, and reprogrammed pcmand tc up to date trans adaptive strategy performed roadtest, concern still present after did tsb .
Removed and replaced trans pan and fine valve cane off and the pan, replaced valve body and topped off fluid leve. replaced module - transmission Road Test rerun eec test ok, done.
Old Aug 23, 2007 | 04:57 PM
  #64
berry1234's Avatar
berry1234
Good for you!
Old Aug 28, 2007 | 03:14 AM
  #65
Newton007's Avatar
Newton007
Carbon M,
Great to see you back on the road in your 07. Let us know how it holds up.
Looks like it was more than a TSB update. This is good to know for future reference. There really was something internal gone haywire.
Old Sep 13, 2007 | 05:10 PM
  #66
HOTSPOT's Avatar
HOTSPOT
Thumbs up
I am having the same issue as described by the original poster. Just under 2200 miles. I will get her updated when she goes in for her service. Thanks for all the info folks.
Old Sep 13, 2007 | 05:17 PM
  #67
carbonmetallic
so far so good, my transmission hasn't acted up any since they did the updates and replaced the valve body.
Old Sep 13, 2007 | 05:24 PM
  #68
HOTSPOT's Avatar
HOTSPOT
That's good to hear man. Mine is generally smooth as silk, unless I make a "rolling stop" then accelerate.
Old Sep 13, 2007 | 05:34 PM
  #69
Newton007's Avatar
Newton007
So far so good here too @1300 miles. One day when It got down to 40 degrees, once and only once did it try to start out in second gear from a stop. When it warmed up, it ran ok. I am watching it though.
But here is something, It seems to me that for some reason the engine sounds louder than it did when it was new. Not a problem, as it has been sort of a slow change, but I have noticed it. Not an exhaust leak or anything, but just louder engine noise, kind of like my 65 Mustang GT convertible had.
Old Sep 17, 2007 | 10:32 AM
  #70
User 9823's Avatar
User 9823
Is there anyway to get these full detailed TSBs free on the Internet ?
Old Oct 9, 2007 | 02:24 PM
  #71
saboola's Avatar
saboola
I am having the exact same problem as carbonmetallic. I have only owned my 07 Expedition for a week, and now its going to be in the shop for over a week while they "reseal the clutches". I dont know a whole lot about cars, so hopefully whatever they do fixes it. This is really depressing. I have never had new car problems like this.
Old Oct 9, 2007 | 02:36 PM
  #72
berry1234's Avatar
berry1234
Hmm. Never heard of reasealing the clutches. Maybe they checked out the clutches and had to reseal the pan?
Here is a copy of the TSB. Show them this if you can't get anywhere.
http://home.pacbell.net/cclary1/MSFa...d4430c6b51.JPG
Old Oct 9, 2007 | 02:42 PM
  #73
saboola's Avatar
saboola
Berry : You ever hear of a "clutch shield"? I had a hell of a time trying to figure out what exactly they are going to be doing over the next week with it. FWIW, I showed them that TSB when I brought it in, and they said it was happening between 3 and 4 and not 1 and 2.
Old Oct 9, 2007 | 02:43 PM
  #74
berry1234's Avatar
berry1234
Yes, that is a legit part. Was your tranny stumbling from 1-2 and 2-1?
Old Oct 9, 2007 | 02:51 PM
  #75
saboola's Avatar
saboola
It sure did feel like it. It would start off fine, early in the day for example. But after sitting in stop and go traffic for a while, it had trouble finding gears, and sounded like the engine was revving high even though the highest I saw the RPMs go was about 2.5k. Even early in the day however, when it was fine, it did feel "sluggish" then would jolt into action after hitting the gas. At first I thought it was the new transmission model, and just the way it felt. Was very different from my 06 F150 4 speed. Now, im not so sure if it was normal.
