2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Transmission Problems?
Old Dec 28, 2009 | 09:48 AM
  #211
FixCNC's Avatar
FixCNC
Yes problem solved.
Old Feb 20, 2011 | 03:15 AM
  #212
Newton007's Avatar
Newton007
Here we go again
Well it has started doing it again @ 17580 Miles. My 07 Expedition 6R75 has been starting out in second gear about 50% of the time. I have had several reflashes done to it since it was brand new. They always work for a while, then it starts doing it again. I only put about 50 miles a month on it, so I just get in the habit of punching it until it goes to low. It is a wonder I have any tire tread left as it usually breaks traction and burns rubber in a forced downshift to low.
So I am going to the dealer (again) for a reflash. I keep thinking that by now they would have the bugs out of the software.
Otherwise it has been a great SUV and the ride and steering is the best of any Ford I have ever owned. It is almost as good as a 1977 Lincoln town car I had way back then. After reading the other 6R75 transmission problem posts here, I think the 6R75 is junk and I wished I could put a E4OD in it. I had a E4OD in a 94 Bronco for 100,000+ miles and it worked flawless and never leaked a drop of oil. Oh well, off to the dealer (again).
Old Feb 20, 2011 | 07:55 AM
  #213
poppie's Avatar
poppie
...........I only put about 50 miles a month on it.........Holy crap,drive the thing,we have just turned 64,000 miles on our 07,had some hickups when new,but now you could not pry our EX out of my cold dead hands,along with a couple other items i will not name here .
Old Aug 18, 2011 | 08:39 PM
  #214
Newton007's Avatar
Newton007
Unhappy This transmission is the (&^$%^& its
Well now at 20,200 miles my 07 Expedition transmission has started to act up again, but this time I may have found a way out.
If you read my posts back to 07 you will see that I have been fighting this transmission problem since it was brand new. The usual factory warranty fix was a reflash that worked for a while but always went back to its old self after about 7 months.
I bought one of those Ford top of the line extended warrantys that cover everything. I took it to the dealer today and they told me that they were going to replace the valve body with a 2011 revised design new one that should fix the problem.
May be for good this time, I hope. it seems that the top of the line extended Ford warranty has to fix the problem or else I can just keep bringing it back until they replace the whole transmission with a new one at no charge.
The really sad part is that I really do like my Expedition and have been thinking of buying new one, but have been holding off until I can be sure they have finally fixed the transmission problems. I really don't want to go through all this again on a 2012.
Anyway it is in the shop today and I hope to get it back Monday (Finally repaired).
Old Aug 19, 2011 | 08:54 PM
  #215
TCAS007's Avatar
TCAS007
Mine does it when cold only. Is that what yours does/did?
Old Aug 19, 2011 | 10:05 PM
  #216
Newton007's Avatar
Newton007
Back when I first bought it brand new in 07 it seemed to want to start out in second gear about half the time when cold, but later on the temperature did not matter. The dealer would reflash it and it would work fine for a while, but soon it started to act up again. One thing I can tell you is that it don't get any better with time.
If you let it go with out a reflash, it will really start doing strange things, like a double bump at every stop sign, start out in second gear, bang in to second if it does start out in low. A bang bang bang when starting out in low sometimes.
Even had a engine over speed one time in third gear.
I hope it is finally repaired this time with the new valve body install.
I am going to pick it up Monday and I will give a report, but will have to put some miles on it to make sure the repair holds up.
Old Aug 22, 2011 | 01:13 PM
  #217
homepukes's Avatar
homepukes
Hope you get things worked out. Mine has been working fine since getting the flash.
Old Aug 23, 2011 | 01:13 PM
  #218
1960's Avatar
1960
I have a 2011 EL with 3500 miles I have been back to the dealer 3Xs now they have even replaced the value body and it still is not right. It sounds just like what you are talking about. The dealer and ford are telling me that this is how the transmission works. I dont understand how Ford can sell a SUV like this and have it work this way
Old Aug 23, 2011 | 01:18 PM
  #219
berry1234's Avatar
berry1234
Any updates?
  #220
berry1234's Avatar
berry1234
What exactly is happening?
Old Aug 23, 2011 | 02:55 PM
  #221
1960's Avatar
1960
when you come to a stop and take off it feels like it is in 2nd and starts to move then it will slams down to 1st. It sounds bad like you are going to leave the transmission on the ground, it shakes the whole car. When you unhook the battery in clear the computer it will work good the 1st time you start it. but will start acting up again the next time you start.
the dealer has reflashed it 3Xs now and replaced the value body. Ford says it tests ok by their test equipment
Old Aug 23, 2011 | 03:15 PM
  #222
berry1234's Avatar
berry1234
This is not how it is supposed to perform. Find another dealer and if that doesn't work, file a lemon law claim. I had to do this with my 07 due to brake issues, its the only thing that got their attention.
Old Aug 23, 2011 | 11:17 PM
  #223
Newton007's Avatar
Newton007
It works, for now
I got the 07 Expedition back Monday and they said that they replaced the valve body and re flashed the computer. The result? It seems to work just fine as I have 20 Miles on it now. 20,220 total miles.
That is the good news, but this is really no different than before as it always works ok after every reflash, but after a while it will start acting up again.
So the real test will not be known for a while.
As always, they had no explaination as to why the transmission acts up the way it does, in fact the service person at this dealer was not much help at all with anything. I am going to go back to the dealer I had before even though it is much farther away, the service is better.
1960, This is not good news at all as I was thinking to trade in this one on a 2012 Expedition to get away from the transmission problem for good.
I would have thought by now they could finally fix the problem once and for all.
Berry1234 is right, your transmission is not acting normal at all. Normally, in my case anyway, a reflash should fix the problem, for a while anyway. It has always worked just fine after every reflash, just not very long.
I was looking on line for some kind of reflash module that I could use my own computer to do my own reflash as taking to the dealer is a PITA as they usually have it for a while and it is the only transportation I have. This time was 4 days.
1960 I would take it back to the dealer and let them know that you are not going away until it is fixed. I had this very same problem since my 07 was new and the dealer tried to tell me this was normal.
Of course it is not normal as it only had 300 miles on it and it was always starting out in second gear and I was shifting it to low myself at every stop sign.
I really do like my Expedition, but this on going transmission problem is a bummer for sure.
Old Aug 24, 2011 | 08:59 AM
  #224
1960's Avatar
1960
I talked to the dealer today and asked to have the company service rep ride with me and then tell me that it is normal. They are going to try to get that done. I do like my Expedition And have always bought Fords but if this is the way I am going to be treated then I guess I will have to look else where.
Old Aug 24, 2011 | 11:35 AM
  #225
Newton007's Avatar
Newton007
I do understand your situation as the same thing happened to me and I have always bought Fords, Mercury or Lincoln. But it is things like this that have me looking around too. I have been thinking about trading in my 07 for a 2012 but have been holding off until I am sure the transmission issue has been solved.
I don't know if it was just this one or all of them. Some people claim they have had no problem at all with their Expedition transmissions and others that have have nothing but trouble with their transmissions. So may be it is the luck of the draw or the transmission may have been built on a Monday morning or something.
But the TSBs tell the story as Ford knows there is a problem and seems to have been trying to get a handle on it for years. Why it takes years, I don't know unless there is some sort of problem in the Ford transmission engineering front office, there is some disagreement as to what to do about it and they can't get their act together. I would say there is a basic design flaw and they have been trying to cover it up with software patches, reflashes and telling the owner that there is no problem.
The really crazy part to me is that after every reflash, the transmission works just fine, but not for very long. Soon it is back to acting up again. I just don't get it. I wish I could find a adaptor or something so I could do my own reflash when it starts acting up with out taking all the way down to the dealer every time.
The Navigator has the same transmission, but I don't know if they are having problems also or not, I would guess so.
I also really do like my Expedition as otherwise I have had a few other problems, but they were all solved on just one visit to the dealer, but not this stupid transmission.
