IHC "Blue" CPS
Old Feb 22, 2006 | 10:19 AM
  #421
John7894's Avatar
John7894
Originally Posted by twags6
I found it useful, but heres my question. How do you test the air gap on the cps and what is the acceptable range? If its wrong, how would you go about changing it?
Thanks
Someone posted a few pages back the IH makes a tool that measures the depth from the cover to the reluctor face. He also said the only way to tighten the gap is to sand/mill/machine the cover to get the right gap.
This makes sense. I would be willing to bet that the stronger magnet is a fix for the different depths that are in use due to the machining/casting variances of a mass produced part. So basically you take the old sensor that can't detect much due to the big gap and replace it with a new one with a stronger magnet.
OR you could just tear down the front of your PSD and mill/sand/machine it if it needs to be tightened up. But since that is costly they just produced a stronger (magnetic) part.
Hope this helps.
John
Old Feb 23, 2006 | 01:06 PM
  #422
empiretc's Avatar
empiretc
Since I started this thread, it is my duty to be the bearer of bad news. See this post:
https://www.ford-trucks.com/forums/s...d.php?t=464744
Now that its running though, I put bluey back in just so I could know if it was a problem, and poop. Truck would not go. The black one is in and its ok. I wonder if DPP will replace or refund this thing since I've only had it a month or so.
Old Feb 23, 2006 | 01:51 PM
  #423
blown99's Avatar
blown99
Sanding and or grinding down the cover is not a big deal. It can be done with out removing anything but cmp. I use a 3m cookie wheel to do the job. I have also had to do this many times with the DT 466E which uses the blue sensor. It all comes down to getting the correct air gap regardless of what sensor you use. All the navistar engines used to come through with shims on the cam sensors. Shims and + or - on parts are due to poor/innacurrate machining which keeps costs down in the end.
Old Feb 23, 2006 | 05:52 PM
  #424
empiretc's Avatar
empiretc
IF its about cost, why did the blue one fail so soon?
Old Feb 23, 2006 | 07:39 PM
  #425
Dually02's Avatar
Dually02
I took the blue CPS out last night. I wanted to see if I noticed a differance. I had the blue one in for 2-3 months now. And I did notice a change. The truck doesn't start as fast, Throttle response is a bit sluggish. I don't know about mileage yet. But I will.
Old Feb 23, 2006 | 08:59 PM
  #426
blown99's Avatar
blown99
If they could fix at a reasonable cost as to why they fail so soon, I would think they would. They have had numerous updates and revised part numbers over the years trying to repair the problem. Navistar did away with this sensor in their new engines VT 365 and the I 313. I still don't get why people install parts that were not meant for there application and then recommend it as a great mod two days after the install, especially with no testing done to verify as a good replacement.
Old Feb 23, 2006 | 09:20 PM
  #427
guzzle92's Avatar
guzzle92
Originally Posted by blown99
..........I still don't get why people install parts that were not meant for there application and then recommend it as a great mod two days after the install, especially with no testing done to verify as a good replacement.
Because we're FTE.
When we do something and the SOTP labs that we use here OKs it, we get the word out. I'm afraid if Ford had it, we still wouldn't know about the Kwik Filter or the fuel bleed systems that Kwik came up with.
Old Feb 23, 2006 | 09:52 PM
  #428
Craven's Avatar
Craven
Than why did IH put the black cmp in the DT466 to make them run better?
Old Feb 23, 2006 | 10:45 PM
  #429
empiretc's Avatar
empiretc
My engine is louder with the black cps.
Old Feb 23, 2006 | 10:53 PM
  #430
Kwikkordead's Avatar
Kwikkordead
Now that's something that makes me interested in the blue one. Quieting the diesel clatter a little would be nice.
Old Feb 23, 2006 | 10:59 PM
  #431
empiretc's Avatar
empiretc
Things have gotten quiet in other places about the blue cps. Even the sites that were pushing them hard with their "improve mpg" advertisements are no longer promoting them as much. Me thinks somebody knows something.
Old Feb 24, 2006 | 05:45 AM
  #432
Fords4Me's Avatar
Fords4Me
And cranks just a little longer with blackie also is my experiance.
Old Feb 24, 2006 | 07:21 AM
  #433
cleatus12r's Avatar
cleatus12r
Butt-Head
Hmmmm. Oh well. I guess I get to keep runnng my blue one because I like the way it runs with it. I'm glad I ran across this thread because I found a simple, inexpensive way to increase my mileage and and quiet my engine down (if only slightly). I say inexpensive because I needed a new CMP sensor anyways for a spare (which is the black one now).
Cody
Old Feb 24, 2006 | 07:28 AM
  #434
Craven's Avatar
Craven
Cody
Dido
Craven
Old Feb 24, 2006 | 07:32 AM
  #435
blown99's Avatar
blown99
The DT did not come through with a black sensor. The black sensor was only used on a very select few that developed a cmp signal noise that could not be "fixed" with a new blue cmp sensor. Usually the truck gets a CEC reflash and a new sensor per engine group.
SOTP feel is nothing. Understanding what you are doing and why it does what it does is the important part. Any idiot can change a part.
The KWIk mod and the fuel line mods are nothing more than a variation (homemade version) of what navistar puts in there 3000 and 4000 series trucks and buses. Its nice to see somebody offers his ideas without a price tag to people that don't know what works and doesn't instead of stealing there money for a mod that doesn't work.
