Methanol/Water Injection
Old Jun 26, 2004 | 08:48 AM
  #586
Choctaw Bob's Avatar
Choctaw Bob
Originally Posted by Tim Lamkin
What does this mean, a bit curious I am
We were chatting about the creeps that attacked him over oil preference.
Old Jun 26, 2004 | 09:03 AM
  #587
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...yea....
Old Jun 26, 2004 | 11:44 AM
  #588
bighoss550's Avatar
bighoss550
...yea....
i am sorry, tim for that post that looked as though it was towards you. it wasnt. u have never once put down anyones right to choice and thats very commendable. i hope i didnt damage any friendships. and i am DONE commenting on oil in any part of this forum!!!!!
i rigged my wires on the injection system, it works and it didnt blow up!!!! woo-hoo!!!
ill redesign the wiring correctly when i have enough wire.
Old Jun 26, 2004 | 12:29 PM
  #589
Choctaw Bob
The creeps give me a hard time about Mobil 1. You can bet they will come out from under their rocks when you start talking about oil. It's taken them a lifetime to memorize their positions because you know they never had an original thought.
How does it run?
Old Jun 26, 2004 | 03:40 PM
  #590
BBBxcursion's Avatar
BBBxcursion
Originally Posted by PSD 60L Fx4
Hmmm I suppose that poses a situation. I had my tank mounted fairly high in a toolbox, and my pump mounted in my console, along with my control box and switch box. The only wires I had to extend were the ones from the boost switches, and 10 extra feet of braided line of which i ran under the carpet, through the steering shaft grommet and into the engine compartment; I ran the line from the tank through the vents in the back of the cab to the tank, and the other end under the carpet into the console.
As for your situation, my best advice would be to relocate your pump elsewhere, if at all possible. A seperate pump would probably work; however if i were you I would call Ken E. and ask him about it first. Do you have a toolbox on your truck?
No tool box....no pick up bed-it's an Excursion. I'll give Ken a call Monday then. I don't really want to move the pump, I like it where it is. Thanks for the advice~! I'll let you know what I come up with.
Old Jun 26, 2004 | 03:57 PM
  #591
Choctaw Bob
Originally Posted by BBBxcursion
The pump is on the side of my AFE Air intake. Thanks for the suggestions on pump preasure-I'll change them tomarrow. One question though......I finalized the install after testing it. My pump in now higher than the tank, so I don't get fluid to it. The pump has some suction, but not enough. Can I just feed the injector pump with a WS fluid pump? There is no gravity to feed the injector pump anymore. Any thoughts/suggestions would be appreciated.
Most pumps won't pump air but if you bleed the air from the lines and put a loop in the line near the tank that is higher than the pump (to hold water against the pump)it may be able to develop enough suction to overcome the section of empty line then it may work fine where you have it. Just don't let it run out of water and it will stay primed.
Another way is to pressureize the tank with boost pressure. Run a line that you tee off the map sensor line to the tank, seal the tank and then it will have 30 PSI or so in the tank to overcome the location.
Old Jun 26, 2004 | 05:09 PM
  #592
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
Do you think my system would benefit from that?
Old Jun 26, 2004 | 05:30 PM
  #593
Choctaw Bob
If your tank will take the pressure! You need a check valve in the line to keep it from pumping water all the time.
It's what we used to do with the carburated blower and turbo cars with 7 psi mechanical fuel pumps. They had a small air bleed hole at the top of the fuel pump and we would tap that for an air line to supply blower pressure.
Your 100 PSI pump is only pumping a net 65 PSI because it has to overcome the 35 PSI boost enviroment that it is injecting in to!
Some kits have no pump at all and just use boost pressure alone.
Old Jun 26, 2004 | 05:33 PM
  #594
SpartanDieselTech
Former Vendor
I think the tank will hold it; ill just have to drill out and plug the vent on the cap. If it explodes, it wont be the first thing on the truck to do so
Explain the check valve for me. How can it get past the solenoids when there closed?
Old Jun 26, 2004 | 05:38 PM
  #595
Choctaw Bob
The solenoids should hold! Re read my post, I edited it some.
Old Jun 26, 2004 | 05:40 PM
  #596
SpartanDieselTech
Former Vendor
I kind of jury-rigged a mock c02 system with some brass pipe nipples, fittings, and the regulator into an X shaped sprayer assembly today. No nozzles or solenoids, just left the elbows where the nozzles would screw into open. Filled up the 2 of the 4 tanks at a paintball place in town for 3 bucks Screwed it in and opened the regulator...froze the carpet on the floor in my room cause i had it laying on it One tank sprayed for a good 30 seconds with no nozzles and the regulator wide open..i was surprised. This thing has to do SOMETHING when i get it on.
  #597
Choctaw Bob
Big? You haven't been on all day! How does your truck run?
Old Jun 26, 2004 | 05:42 PM
  #598
SpartanDieselTech
Former Vendor
Well with the pump regulator wide open the gauge reads almost 225...its rated to put out 250....i was just wondering if at that pressure it even matters. If it does, i will hook it up and try it out. All i need is a rubber hose, some clamps, and a fitting to hook it into the tank, correct?
Old Jun 26, 2004 | 05:44 PM
  #599
Choctaw Bob
All of it will help some. You are gonna find which gadgets work in purportion to the amount of maintenance you have to provide.
Enough c02 sprayed in a closed room can kill you!
Old Jun 26, 2004 | 05:46 PM
  #600
SpartanDieselTech
Former Vendor
Woops Now that I know that Im glad Jenna wasnt in my bedroom when i did that... i emptied the whole bottle...but the doors were open
As for maintenance, I have no life...nothing better to do besides screw with the truck
