Methanol/Water Injection
Old Jun 23, 2004 | 09:51 AM
  #466
Choctaw Bob's Avatar
Choctaw Bob
Originally Posted by Tim Lamkin
I can only imagine that the ramp angles must be extreme to obtain the kind of HP numbers he is, that really wacks out idle.
The biggest disappointment about this engine is that as originally advertised by IHC this engine had electronic/hydraulic actuated valves. This would give you ANY cam profile in the computer program. The ultimate tuneable engine!
The 4.5 was also advertised to have this feature. This is probably the delay in the 4.5, making it reliable.
If the 4.5 comes out with this feature in the F-150s, it will be able with a predator, to produce more power than the 6.0.
Old Jun 23, 2004 | 10:14 AM
  #467
Choctaw Bob
Originally Posted by bighoss550
those big cams may make more hp, but they dont make much more torque unless he ups the boost press.
i have always read and my experience w/ turbo diesels proves to me, a stock or VERY slight cam is where the POWER is at. once u start getting up in duration, u start gettin overlap unless u stretch the lobe angle. the more overlap u have, the less effective the turbo is, making u spin much higher rpm's. wide LA's are no good either.
get the stock style cam, and if u want more power, turn the boost screw!!! thats why we have turbo's in the first place, right?
for ex. i am building a 514ci caddy V8 that has two turbos. it burns gas from the primary's and methanol through the secondarys. ross pistons, H-beam rods, o-ringed block, anyway, it is in the range of 1200-1400hp and 1700lbs of tq! but the cam has LESS duration than stock!!!
You are exactly right. More overlap won't hold blower pressure. To build pressure you increase lift and reduce overlap. By doing that you also reduce the peak RPM that the HP is made. Makes for a longer living engine.
My friend's Pro 5.0 Mustang race car makes 2,600 HP from a small block Ford.
He regurally beats the Chevy nitrous mountain motors.
Old Jun 23, 2004 | 11:58 AM
  #468
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
I am going to go with the stock cam duration. These trucks have insanely wide powerbands for a diesel to begin with, not much need to make it even more. What effect will increased lift have? Better breathing?
Old Jun 23, 2004 | 12:02 PM
  #469
Choctaw Bob
Better breathing without longer duration. Sometimes you can increase lift and shorten duration to build more torque earlier.
Old Jun 23, 2004 | 12:03 PM
  #470
SpartanDieselTech
Former Vendor
If you make the torque earlier, will still maintain it all the way to redline?
Old Jun 23, 2004 | 12:07 PM
  #471
Choctaw Bob
Sure. But it takes an experienced cam grinder to make this happen.
If you want to find out how cams work, play with the program Mr. Gasket Desktop Dyno.
Old Jun 23, 2004 | 04:05 PM
  #472
bighoss550's Avatar
bighoss550
increased lift w/out longer duration makes a steep ramp on the cam and this is bad for valvetrain geometry. thats why roller cams make more power, cuz they can have really steep lobes, making the valve open farther, sooner.
if u want better breathing, just turn up the boost more press=more air=more fuel=more power....fun stuff i love turbos!!!!
Old Jun 23, 2004 | 04:09 PM
  #473
bighoss550's Avatar
bighoss550
desktop dynos are a lot of fun and are suprisingly accurate!! (except w/ nitrous, cuz it doesnt calculate it very well. it just adds the amount to the existing hp #'s. but it gives an idea)
i love mine and im on it almost as much as im here
  #474
Choctaw Bob
Ah!, but hydraulic rollers are available now! They reduce parasitic losses and allow the steeper ramps. Boost can be turned up to a point, but valve timing is the heart of any engine!
Old Jun 23, 2004 | 04:10 PM
  #475
bighoss550's Avatar
bighoss550
i got the pump today!!!! time to play
Old Jun 23, 2004 | 04:11 PM
  #476
Choctaw Bob
I wonder whos pump I got?
Congrats! When does it go on?
Old Jun 23, 2004 | 04:15 PM
  #477
bighoss550's Avatar
bighoss550
does the 6.0 have rollers? and i bet california kids mountain motor will run out of fuel to pump before the twin tuba's get to their limit!!
but u are very right about the heart of the engine. "power is made in the heads" a wise man once told me. he was right
  #478
SpartanDieselTech
Former Vendor
Well, I would turn the boost up. But the problem is that two turbos wont put out more than 120 lbs of boost. It will already be running at that. The only thing past that for power (or getting air for the power) is valvetrain. Nobody makes a tri-turbo kit yet
I just want something that gets lots of torque, gets it quick, and carries it to redline. That is my goal.
Oh, dont worry bout that. Im getting a new fuel pump too
Old Jun 23, 2004 | 04:16 PM
  #479
bighoss550's Avatar
bighoss550
the install begins tomorrow....dun, dun, duuuunnnn
Old Jun 23, 2004 | 04:17 PM
  #480
SpartanDieselTech
Former Vendor
What size orfice did you decide on?
