question for jwtaylor
Old Jan 14, 2004 | 08:50 AM
  #121
jwtaylor's Avatar
jwtaylor
f100guy
I have heard of people adding forced induction to the six with good results. The knocking sound might be a good excuse to rip that motor out and install new bearings, stronger bolts and forged pistons. , then a little forced induction or Nitrous oxide might be in order. haha I think keeping the mustang a six and working off that, is a great idea. Well good luck with both cars. Later
Old Jan 14, 2004 | 09:33 AM
  #122
f100guy's Avatar
f100guy
i wanna make the 4.2 stroker and put some afr heads with underdrive pulleys and a chip and better injectors. that should put it over 300 hp.
Old Jan 14, 2004 | 09:49 AM
  #123
jwtaylor's Avatar
jwtaylor
They make afr heads for the 3.8? I didn't know that, and yeah I am sure they would make some hp. Sounds like you have a plan. The 3.8/4.2 use the same block don't they, or not? Would it be a matter of using a 4.2 crank/rotating assembly, out of a truck engine? I don't know much about this and would be willing to learn. I know I had a short bed f-150 with a 5-speed and the 4.2 v6 and liked it a lot, that little engine with the manual tranny made for a fun truck. I could roast the tires like nothing, more than one person thought I had a v8 in it, because they asked and looked funny when I said no, its a v6. later
Old Jan 14, 2004 | 12:29 PM
  #124
f100guy's Avatar
f100guy
i know i drove a 97 ext. cab with a 5 speed and it would smoke them for a long time. but it was not mine. i know little about this motor and i am researching different kits now. i was just told by this v6 loving 03 mutang driver about all the different stuff they have. he is a stang nut. i wish i could find a turbo'd tbird 3.8 and rebuild it and put it and the computer in this car. with all the afr stuff. i would leave all sorts of v8's behind. but i am not sure about the 4.2 and the 3.8 share the same block.
Old Jan 15, 2004 | 07:39 AM
  #125
adilts2002's Avatar
adilts2002
to stroke it that far is almost nposible
those cylender walls arnt that think on them 3.8's and if you would stroke it that far you would have to almost desinge a new lower blockLOL. i would prbibly bore is 0.030 and plain the heads or block then get ur heads on it you can get superchargers prety cheep on ebay. then get a smaller pully for it, headers stuff like that. mine runss pretty smooth
Old Jan 15, 2004 | 07:42 AM
  #126
f100guy's Avatar
f100guy
i was told that the 4.2 v6 was a stroked 3.8. that would be cool to put a 4.2 v6 in the car with a chip and headers that i already have installed and true duals which i have that on the stang too.
Old Jan 15, 2004 | 09:56 AM
  #127
jwtaylor's Avatar
jwtaylor
f100guy
I found this link to back up your idea of the stroker, shouldn't be too hard to find a junker 4.2 to take the rotating assembly out of, and I have seen the 3.8 super coupe superchargers on e-bay, so seems the sky is the limit. I also read that the bellhousing is the same as a 302 . Check this link out it has some good points about possible heads gasket problems and options for the 3.8. Later
http://www.foxthundercats.com/3_8V6tips.htm
Old Jan 16, 2004 | 10:04 PM
  #128
f100guy's Avatar
f100guy
thanks i finally got the intake off and did you know it has a roller cam. it has the spider bars and roller lifters. i wonder if this is an add on or something. i did not know they had roller cams
Old Jan 17, 2004 | 09:26 AM
  #129
jwtaylor's Avatar
jwtaylor
Can't say whether or not they all where roller or not, regardless its a bonus that you have one.
Here is a link that has performance sources and ideas for the 3.8:
http://www.coolcats.net/tech/general/v6.html
later
Old Jan 17, 2004 | 10:10 AM
  #130
f100guy's Avatar
f100guy
thanks for that i may wanna look at that cam. i am gonna port my heads and intakes myself since they are aluminum and will be quite easy. i wish the 5.0 injectors would work. i wonder if they would. this motor is the hardest thing to take out.
Old Jan 17, 2004 | 03:28 PM
  #131
adilts2002's Avatar
adilts2002
the 5.0 injectors will work but there exactly the same
no difference. id up ur fuel pressure about 5-10 lbs and get 10% bigger injectors im gonna try that so ill tell u how it is oh id say about tuesday
Old Jan 17, 2004 | 06:58 PM
  #132
f100guy's Avatar
f100guy
the v8 ones are orange
Old Jan 17, 2004 | 07:19 PM
  #133
jwtaylor's Avatar
jwtaylor
Adjusting the fuel pressure. Thats a trick the inline, speed density, crowd uses to hopefully gain some hp, it only works if the computer runs the engine extremely lean. I would do it only if I had an accurate air/fuel meter to insure what I was doing wasn't exceeding an optimal air/fuel level. Thats my opinion though. F100guy your gonna have to take some before and after shots of your head porting work. later
Old Jan 17, 2004 | 10:49 PM
  #134
f100guy's Avatar
f100guy
ok cool i may do it tomorrow since i may have to wait for a new clutch disk
Old Jan 19, 2004 | 06:36 PM
  #135
f100guy's Avatar
f100guy
i installed the clutch and ported the exhaust ports and i have pics. i will send them
