question for jwtaylor
Old Dec 13, 2003 | 10:19 PM
  #31
f100guy's Avatar
f100guy
yes i have duraspark. but when i put it in the tbird i either have to change the ignition system from tfi or keep the fuel injection. i don't wanna do that since there is money used on my new carb and intake. and i don't really feel like rewiring a new duraspark ignition, so i will try this hei conversion first since i can use a carb and not have to rewire everything.
Old Dec 13, 2003 | 11:52 PM
  #32
f100guy's Avatar
f100guy
i tried to put my truck radiator it the car and i need to notch out a part of the frame so i think i am going to do that first tomorrow just to have it taken care of. the fan has enough room so it does not need an electric fan. is there a way i can get some custom radiator hoses made.
Old Dec 14, 2003 | 07:15 AM
  #33
adilts2002's Avatar
adilts2002
jwtaylor-what do you mean the procedure dont work for a aodtat i mentionedihavent had anyproblem with adjustingthem like thatalong with the AODE it is how i was taught in school to adjust them. how do u adjust them?
Old Dec 14, 2003 | 07:31 AM
  #34
adilts2002's Avatar
adilts2002
f100 guy you can make your on costom hoses all you have to do is go get some hi temp pvc pipe and cover it with your rubber so it looks beter then the pvc pipe. i know this is some red neck rigging but ive done it lol
Old Dec 14, 2003 | 12:12 PM
  #35
f100guy's Avatar
f100guy
sounds good if i need to make some custom hoses then i will do that
Old Dec 14, 2003 | 12:18 PM
  #36
jwtaylor's Avatar
jwtaylor
f100guy
If you use your duraspark ignition all you have to do is find a couple of sources of power to hook it up. YOur main objective would be to keep the distributor, coil and module in tact as they are. Then connect the wires out off the module (3 or 4) to the proper connection, which would consist of a constant 12 volt source and a 12 volt source with the key on. Not too big a deal, and its free since its there. Thats just a thought though, if you would rather do it the HEI way then that sounds like a plan. You could use a hose you have laying around and figure out a way to make a template of how it should looks. Then go to an autoparts store and see if they will let you or they will go find one that is close. I have done that before, not to mention they do sell universal hoses, just make sure the hose fits connections properly. Good luck sounds like you making some good progress, are you taking pix?
adilts2002
I thought you had a plan on your describing the adjustment of the bands on the aod. Thats how its done on my c6, but to be certain I did some searching, I looked in my haynes then gathered all info I could on the net, and well, there are no external band adjustment on the aod, from what I can find. In a few cases those exact works where written, no external band adjustment on the aod. later
Old Dec 14, 2003 | 02:22 PM
  #37
f100guy's Avatar
f100guy
i was going to take pics of the old motor and my radiator fittings
Old Dec 14, 2003 | 07:12 PM
  #38
f100guy's Avatar
f100guy
ok i got my 3 core radiator in and it fits great
Old Dec 14, 2003 | 07:34 PM
  #39
adilts2002's Avatar
adilts2002
well jw taylor i guess im thinking of the AODE or im just mistaken but i thaught some of the aod trannys had an out side band . we did have some chevy trannys there at the time so it might have been those, sry but thankx
Old Dec 14, 2003 | 08:12 PM
  #40
f100guy's Avatar
f100guy
umm
Old Dec 14, 2003 | 11:15 PM
  #41
f100guy's Avatar
f100guy
http://photos.yahoo.com/viperman40
those are my photos of my stuff and project. i got the 3 core radiator in there with no problems. i knew it was going to work.
Old Dec 15, 2003 | 07:09 AM
  #42
jwtaylor's Avatar
jwtaylor
f100guy
Looks like it does work. Is that older ford with the newer flareside bed with the big ol tires yours? later
Old Dec 15, 2003 | 10:20 AM
  #43
f100guy's Avatar
f100guy
no i wish i saw it going down the road so i took a pic
Old Dec 15, 2003 | 12:43 PM
  #44
jwtaylor's Avatar
jwtaylor
Done anything to your car today?
Old Dec 15, 2003 | 03:08 PM
  #45
f100guy's Avatar
f100guy
no i had to haul off a ranger to get some money. but later i am getting under it and undoing the tranny lines and mounts.
