nothing like them. the rubber is round and the point straight down. but i think i could just wrap a chain around the crossmember and the mount and chain it tight just for a quick fix until i get the money. i will post more pics when i get some new batteries for the cam.
i usaly use gas to clean parts a lil stronger then diesel and it dont leave an oily finish to it. or you could go to autozone and get aircraft remover but beshure to read the can that stuff burns on skin.
i welded the motor mounts back solid and switched the oil pan i am going at a slow speed due to other things i have to do. i was finally enrolled in college today to be a diesel mech. then i can help all with there power strokes.
Gonna be a diesel mechanic, huh? Sounds like a good idea, congratulations! A few years you'll be making all kinds a money, and who knows, by then you might be trying to put a diesel motor into that t-bird. Well you have the mounts ready so, all you have left is what? Switch them out. Getting closer everyday, later
i have to drop the tank still and change the pump. i tried to get fuel through the in tank pump and my pump would not get none so i still have to do that and i still need to install my b&m shifter and get a cable and also make a brackter to fit on the tranny to hold the cable
no i am being held up. i worked on the power steering pump trying to switch out pulleys and brackets. how do you get the pulley off. it sucks. i wanna make the branket ofr the cable before i put the motor in though
ok i am going to drop the motor in day after christmas. i took the ball mount think off of the aod and welded it to the c5 shift lever. not i just need do make a mount to hold the cable tight and straight. i am just going to use the old shifter and just fell for the gears until i get the money to get the b&m cable. i need to change the rubber on the steering shaft but i think i may just weld it solid since right now i am poor and nobody wants to hire anybody right now. do i am rigging everything but that's ok if it works go with it. i have a friend that works at napa doing my power steering pulley for free. i wanna know if there is any way i can bypass the in tank pump just by running a pickup tube before the pump and then into the tank. i don't wanna have to find a different sending unit. i just wanna bypass and suck some fuel.
i got the cable and made the bracket. it finally works right. now i am putting the tranny onto the motor and putting the motor mounts back on. then i am going to do something about the steering rubber coupling. will have pics soon.
Glad to see you have it coming together. You could rig up something to draw fuel from the tank, like you mentioned. Well, again good luck, and will take a look at those pix. I saw a commercial for a new automotive show the other day, and I am almost certain, there was a lamborgini that had a similar color as your car in the background. Does that mean anything to you? Probably not. Just thought I would share. later
