question for jwtaylor
Old Dec 11, 2003 | 06:37 PM
f100guy's Avatar
f100guy
it is getting worse and worse. slips very bad and i have no money. do you have any knowledge about the 4 speed manual transmissions that came in the 74-78 mustang 2's with the 302. i have one and i might wanna use it. is it a toploader
Old Dec 11, 2003 | 09:27 PM
adilts2002's Avatar
adilts2002
ok the band is a 5/16 or a 3/8 square bolt type deal with a bigger lock bolt next to the tranny usaly about a 7/8 or 13/16 losen the big nut up and twist the small inner bolt in untill it touches. dont pry it in just till it touches and then back it off 1 turn and tighten the big nut as you hold the square nut in place. I think that might set you up good maybe not but worth a try. I do think the "plug that you mentioned is the band adjustment i think that is what realy messed you up try to adjust it for ****s and giggles and see what happends . it should only take about 10 min and might save you a lot of cash. let us know what happnes , Andy
Old Dec 11, 2003 | 09:29 PM
adilts2002's Avatar
adilts2002
oh another thing this is a truck were talkign about right? well if it is you cannot use a mustang gear box because the car gear boxes the shifter is at the back of the tranny and a top loader fot the trucks it is in the middle of the tranny but still a top loader i guess the mustang one would work if you had bucket seats.
Old Dec 11, 2003 | 10:00 PM
f100guy's Avatar
f100guy
no it is a 91 5.0 tbird will the 4 speed work in it. i am sure it will but i wanna be sure
Old Dec 12, 2003 | 07:30 AM
jwtaylor's Avatar
jwtaylor
f100guy
the procedure adilts2002 mentioned is for a c4/c5/c6 transmissions, not the aod. You should be able to make the manual tranny work but you will still need to find the clutch pedal, clutch line etc to make it work, depending on whether or not you use a hydralic or cable actuated clutch. You will probably still have to modify the driveshaft and crossmember, althought I am not positive. Not trying to tell you what to do, just asking, is waiting around and having it rebuilt or rebuilding the aod yourself out of the question? Or do you just want a 4/5 speed manual? Later
Old Dec 12, 2003 | 09:39 AM
f100guy's Avatar
f100guy
i always wanted a manual tranny and if i can get one i will use it. i have no money whatsoever to get it rebuilt or to get the parts. the 4 speed i have i found out that it is a RAD and it is not strong for nothing. i am not really in a hurry since i have another car to drive. but i am going to miss the power for a while.
Old Dec 12, 2003 | 12:03 PM
jwtaylor's Avatar
jwtaylor
Well can't argue with that, I like a 4/5 speed myself. Maybe you can find someone to trade a decent manual trans for all of yours, you just never know. Well good luck in your search, maybe you will obtain some $$$$ and have it in there in no time. later
Old Dec 12, 2003 | 12:22 PM
f100guy's Avatar
f100guy
i found a srod 4 speed but i need to know what i will have to do to make it a hydrolic clutch since the tbird has no plase to mount the linkage for a clutch
Old Dec 12, 2003 | 02:21 PM
jwtaylor's Avatar
jwtaylor
You might try finding an actual 91 Super coupe or around there t-bird that had the manual tranny, or search the internet for conversions you should be able to find something, if I come up with anything I will point you in the direction. later
Old Dec 12, 2003 | 02:40 PM
jwtaylor's Avatar
jwtaylor
well this was the first link I found and it states that they didn't know if a hydraulic clutch would work as far as a donor pedal assembly. However it lets you know how to put a t-5 in your thunderbird it refers to 5.0 cougar but the t-bird and cougar are baiscally the same thing more or less. Take a look:
http://www.coolcats.net/tech/advanced/t5conversion.html
Old Dec 12, 2003 | 08:34 PM
f100guy's Avatar
f100guy
thanks for the info i changed my mind that is a lot of work and would cost a lot. hopefully it would not cost to much or too much work to put in a c5 or something
Old Dec 13, 2003 | 01:47 AM
f100guy's Avatar
f100guy
ok i started to take the old 5.0 out and you would not believe how nasty the lifter valley and under the valve covers was. they both had about an inch of sludge and crap. it was thick. i stuck my finger in it and it felt like cake icing that is a couple of days old. it was that hard. my friend picked up something out of the head and thought he found something that was chipped off. i took it and broke it in half. it was smooth but still just hardened gunk. i can't believe this thing ran this long and good as it does. and this is the first time i have ever opened up and seen a roller block. are the newer cars auto transmissions operated by cables under the car or by levers and linkage like on a truck. i hope whatever it is that it can shift a c5
Old Dec 13, 2003 | 04:20 PM
  #28
jwtaylor's Avatar
jwtaylor
All the auto truck or car automatics are realitively the same in how they shift etc. So are you going to keep the roller block and rebuild or just replace it with the one in your truck? Sounds like your having fun, later
Old Dec 13, 2003 | 06:13 PM
  #29
f100guy's Avatar
f100guy
i am going to rebuild it one day but i am probably going to put the roller block in the truck and use the motor i built it the car. i found a way to bypass all that work of rewiring the ignition. i can convert it to an hei easier and faster.
A lot of guys when converting from fuel injection to carb use the Duraspark II system. This requires pulling out the TFI distributor and coil and replacing them with the Duraspark distributor, coil, module, starter solenoid, and ballast resistor. Yeah its complicated and can get spendy but what else is there besides an even spendier aftermarket system? Well, if you don't mind a little cross breeding you can use a GM HEI ignition module. All that's required is a Duraspark distributor, HEI module, and coil. Because of the dwell control and current limiting circuits of the HEI you can use just about any coil you want, including the TFI coil, and no ballast resistor is needed.
If you are converting from fuel injection all you will need to buy is a Duraspark distributor, HEI module, and some wire and connectors to hook it all up. The cheapest place to get the Duraspark distributor is at a junk yard or swap meet, usually $20 or less. Duraspark distributors came on Ford cars and trucks from the mid seventies through the mid eighties. Make sure you get one from a 302, the 351w and 351c-460 look similar but are different. You could also get a rebuilt one at the auto parts store, generally $40 or more. Make sure you get one with the right gear for your cam. Flat tappet cams use a cast gear where roller cams use a steel gear. If you look at the shank above the teeth a cast gear will be a rough cast finish where a steel gear will be a smooth machined finish. If you want a distributor with a cast gear tell the parts guy you want one for a 5-speed '84 Mustang GT. For a steel gear tell him you have a 5-speed '85 Mustang GT. If the guy at the parts store has two distributors listed and doesn't know which is which, the one with the cast gear is always considerably cheaper than the one with the steel gear.
For the module you want a GM 4-pin HEI. They came on GM vehicles from the mid seventies through the early eighties. You can buy one new at any auto parts store. Any good parts guy will know exactly what a four pin HEI module is. Although good parts guys are hard to find so you will probably need to ask for an ignition module for a '78 Comaro with a 350. Since they are so cheap you don't need to go to the junk yard. Besides, all the junk yards around here wouldn't even sell me just the module, they wanted me to buy the whole HEI distributor to get it. The module in the picture is a Car Quest #21040 and cost me $17.77. As you can see there are four pins labeled W, G, B, and C. The G pin is a 3/16" (0.187") male quick disconnect and the rest are 1/4" (0.250") male quick disconnects.
The HEI module gets pretty hot, whatever it's mounted to needs to act as a heat sink and carry heat away from it. Mount it securely to a flat metal surface away from the headers or other heat sources. There are two pins on the back of the module that you need to break off so it will sit flat. The module will come with some heat sink compound, smear it evenly over the back of the module before bolting it down. The compound aids heat transfer. You could also mount the module to a big heat sink. I bolted mine to a heat sink from a slot type computer processor. If you're a computer geek like myself then you probably have one laying around. If not then you can buy one at Radio Shack or a computer store. Again you will want to use the heat sink compound between the module and heat sink.
Once you have it mounted you need to wire it up. The B pin goes to the positive coil lead which gets power when the key is on, and C goes to the negative coil lead. The tach. also hooks to the negative coil lead. If you are converting from fuel injection then the coil is already wired for power (red) and tach. (green). Splice into these wires. Don't remove them from the coil just add some wires to them and run them to the module. On an older car you will need to bypass the ballast resistor so you get full power to the coil and module. The Duraspark distributor has a funky three pin connector. You can just plug into it with standard 3/16" female quick disconnects. The purple wire is run to the G pin on the module, and the orange wire is run to the W pin. Run the black wire to one of the mounting screws on the module. The black wire provides a solid ground connection for the module. The module must be grounded or it will not work properly.
Like I said before you can use just about any coil you want. Basically the only coils that you can't use are aftermarket coils which are for CD (capacitive discharge) ignitions only. I recommend the TFI coil, its the square looking coil used on fuel injected Fords. They are dirt cheap and work great because they were designed for the Ford TFI which is basically the same thing as the GM HEI. If the TFI and HEI modules are the same then why can't I use the TFI? The TFI distributor uses a Hall sensor instead of a magnetic pickup so the TFI module will not recognize the "analog" signal from a Duraspark distributor. However, you could hook a TFI module to breaker points since they put out a "digital" signal like the Hall sensor. No matter what coil you use you will not need a ballast resistor. The purpose of a ballast resistor is to add series resistance to limit current through the coil. The HEI actually measure the current and when it reaches a certain point resistance is added using the switching transistor to prevent excessive current draw. So basically it has a built-in self adjusting ballast resistor.
That's all there is to it. Whether you are converting from fuel injection or piecing together a weekend warrior the HEI is hard to beat. Its easy, cheap, and a great performer. You could spend five times more on an ignition and chances are you won't see much, if any, improvement.
Old Dec 13, 2003 | 09:41 PM
  #30
jwtaylor's Avatar
jwtaylor
Got a question, doesn't your truck engine have a distributor (ignition) on it? Any reason why your wanting to use something else? later
