7.3 recall
Old May 20, 2024 | 05:55 PM
  #106
techfile's Avatar
techfile
Originally Posted by Boss598
Just remember it looks like this update will be expanded down the road as software becomes available.
Total number of vehicles affected likely will not change. The FSA VIN list will get expanded as the software becomes available.
Old May 20, 2024 | 07:08 PM
  #107
FishOnOne's Avatar
FishOnOne
So Ford encourages dealers and customers to have this update done as soon as possible per their document, but takes their sweat azz time to implement code for the rest of the 7.3's.
Rome is Burning...
Old May 21, 2024 | 05:04 AM
  #108
mainer1986's Avatar
mainer1986
2nd Gear
I looked into it yesterday. My 2024 F350 build date is Feb 24.
I checked my VIN on the Ford recall page and nothing was listed. I also search by model and year and nothing came up for any 2024 or 2023 Super Duty. Any chance it is just to soon for this one to be in the system?
I also called Ford customer support and they said my VIN wasn't shown to be affected. They said that the dealer could have done the update prior to delivery to me. I doubt that because I had ordered this and was notified as soon as it was delivered in March and picked it up right away, long before this recall was announced. She also said if they had performed the recall there would be record of it at the dealer.
I then stopped by the dealer and the service guy I spoke with had no knowledge of it until I gave him the CSP #. After pulling it up he said once they got the notices they would perform the update for my vehicle. He said give it a week or so and check back. He made it sound like the recall VIN's hadn't been received yet. I'd like to think the dealer will eventually be able to show me something that either my truck needs the update or already has it.
Old May 21, 2024 | 05:37 AM
  #109
GetMore's Avatar
GetMore
While anything is possible, the fact that there were three different pressure readings makes me believe it is an actual reading. (They were 95 on startup, 21 at idle, and 51 @2k in drive.) I could see a 2 level sensor (bad/good/high), but three or more seems excessive. Might as well use an actual transducer at that point.
If we want 'proof', without installing a manual valve I would try seeing what happens at cold startup. If the pressure curves down it should be safe to say it is 'actual. If it only has those three (or four, for zero pressure) then it could be 'fake'.
Old May 21, 2024 | 07:13 AM
  #110
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Algorithms are very good at simulating data.
I wish I still had my 6.2L, or I'd hook up Forscan and see what it said.
I have been waiting 4 months for Helm to get service manuals in stock for my '24 7.3L too...
So I'm stuck for now.
Old May 21, 2024 | 10:02 AM
  #111
Hwkdrvr's Avatar
Hwkdrvr
I still wonder why my 2022 F250 Superduty is different than an Econoline built in the same year with a 7.3L. Do we know for sure it is a software/blackbox issue or is it an engine serial number/assembly factory issue?
Old May 21, 2024 | 11:04 AM
  #112
techfile's Avatar
techfile
The E series and F series vehicles will have a different engine and transmission calibration's because of their intended use. E series were designed for commercial, RV and work truck use. F series more for the personal market of luxury and recreational use.
Old May 21, 2024 | 11:19 AM
  #113
Hwkdrvr's Avatar
Hwkdrvr
So, same engine, just different calibrations (ECM, etc) due to different intended use is what you are saying?
Old May 21, 2024 | 11:22 AM
  #114
scraprat's Avatar
scraprat
Top Answer: 5
I'll put another 8,000 miles on mine for the next oil change while you guy's quiver and shake about a flash.
Old May 21, 2024 | 11:31 AM
  #115
techfile's Avatar
techfile
This is my best educated guess as to why. It would be nice to have a Ford engineer who really knows the criteria and qualifiers for the engines that need this software update to explain it here to the forum. Any Ford engineers here to provide comment?
Old May 21, 2024 | 11:44 AM
  #116
capt caper's Avatar
capt caper
I'm shaking cause I had to nap one long road trip day with work. The wife didn't but when I woke after 50 min I belive up she said it was making a clunking sound now and then. I asked her what exactly sounded like etc. Being a girly she could not get me to even guess what it was. Was it lifters rubbing and or hanging up? Bet you life I'm shaking. I have to nap often on these road trips and leave the truck running due to temps below zero or 100 deg f outside.
Old May 21, 2024 | 12:40 PM
  #117
Dozzer's Avatar
Dozzer
And on Mororcraft Blend Oil, not even Amsoil you daredevil lol.
Old May 21, 2024 | 12:41 PM
  #118
Dozzer's Avatar
Dozzer
maybe AC cycling?
Old May 21, 2024 | 12:43 PM
  #119
capt caper's Avatar
capt caper
Originally Posted by Dozzer
maybe AC cycling?
good point. It may of been on. It was on that day. Humid and warm out so I was running it. But clunk? who knows what the wife hear or saw. I guess in time I'll figure it out. I haven't used it much with the ac on this spring (got the truck dec) with the weather being cool all spring in Norther NH.
Old May 21, 2024 | 01:23 PM
  #120
scraprat's Avatar
scraprat
Top Answer: 5
Crazy idea....idle the truck when done traveling for an hour or so and don't sleep.
