7.3 recall
Old May 18, 2026 | 10:23 AM
  #226
travlnman's Avatar
travlnman
Originally Posted by saratoga2011
After reading service data further, it would likely be a bad idea to unplug or disable the oil pressure control solenoid permanently.
Apparently, there is not a traditional spring-loaded check relief built in to the lubrication circuit, it relies on the PCM controlled oil pressure. Disabling the solenoid gives you all the pressure all the time, and while that's fine in toasty central FL, you may regret the decision in a cold climate because it could exceed the oil filter's ability to remain in one piece or worse yet, pop the front and/or rear seals. I saw 95 psi on cold start this morning.
Don't think I'd worry about this much. If your filter blows at 100 PSI, you have a filter problem. Seals themselves rarely see the full PSI delivered by the pump. My wife's 22 Mustang GT has an actual pressure gauge showing real time PSI, and on a cold winter morning I've seen over 100PSI, with no issues. Others may chime in with more experience, but I'd rather have the PSI, than not have it.
hogryder007
Jan 12, 2025 08:24 AM
someday
6.2L V8
23
Aug 14, 2023 12:34 PM
bocomojoe
Large Truck
Sep 12, 2019 04:08 PM
FloridaF250
May 8, 2008 07:01 PM
Bucky
Dec 16, 2003 10:24 AM
