More problems😑
Old Mar 30, 2022 | 04:08 PM
  #106
ESwift's Avatar
ESwift
CNCFAB
I have bent that pipe on one if my trucks before when I was getting the hang of doing my own work. 14.5 years ago when I got married at 21 years old I didnt even know how to change my own oil….so you are waayyy ahead if me.
I think you would be ok with just buying a longer boot for now. That is the cheapest option that will work.
I have used these boots and they are very good quality. I am not sure if it is ling enough for what you need though, I can measure it
https://smile.amazon.com/gp/aw/d/B09...b_b_prod_image
Old Mar 30, 2022 | 04:29 PM
  #107
Hyakkimaru's Avatar
Hyakkimaru
I started working on my own stuff about 1 1/2 to 2 yrs ago. I'm still a novice.
I'd appreciate the measurements.
I take it that being as the riffraff boots are recommended over that style of boot, the dimple inside the boot really does help hold the pipe on? Both the 3 inch 4ply straight coupler I was looking at and the one you just linked don't have that dimple. Is it really that helpful in holding? Or is it mostly for helping line everything up?
Old Mar 30, 2022 | 04:36 PM
  #108
FordTruckNoob's Avatar
FordTruckNoob
The RiffRaff y-pipe boot has that ridge on the inside to engage the groove on the CAC pipe also. It won’t help in your case because the end of the CAC pipe where the groove is is all conical and squishy now.
Old Mar 30, 2022 | 04:38 PM
  #109
Walleye Hunter's Avatar
Walleye Hunter
I started working on mine about 45 years ago and I'm still a novice too so make sure and double check and verify anything I suggest.
Old Mar 30, 2022 | 04:55 PM
  #110
Hyakkimaru's Avatar
Hyakkimaru
That's what I was asking about in my last post. Is that ridge actually helpful for holding the boot in place or just for lining it up? I was just wondering if boots without that ridge would hold just as well or if you lose the strength between the pipe and the boot. I may just have to bite the bullet and pay $170 for some boots. It's going to be a while though.
Old Mar 30, 2022 | 04:58 PM
  #111
FordTruckNoob
Oh it definitely helps to hold the pipe in when the part with the groove isn’t squishy.
Old Mar 30, 2022 | 04:59 PM
  #112
jstihl's Avatar
jstihl
I remember talking to clay about this years ago and he said he didn't think the dimple was any better but people kept requesting it so they put them in. I guess it's just a preference
Old Mar 30, 2022 | 05:36 PM
  #113
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Another idea for the herky IC pipe; if you have a bench vise open it up until the external shoulders fit inside the pipe. Move the pipe up and down so the vise runs inside the pipe to push out the bumps. Might be able to round it back into shape. Some grease or oil will help.
Easy to demonstrate but hard to describe the concept, sorry.
Then sand/clean/hairspray/sacrifice chicken.
Old Mar 30, 2022 | 05:42 PM
  #114
Hyakkimaru's Avatar
Hyakkimaru
It's funny. I have that exact vice. Don't know about that one but mine is from China though. It was free because it was messed up and I fixed it.....
That's a good idea but even rounding it back off isn't going to help anything I don't think. It's too soft now.
Old Mar 30, 2022 | 06:42 PM
  #115
ESwift's Avatar
ESwift
CNCFAB
The boot I posted the link to is 4”, same as Riffraff boots, so about 1” longer then oem
Old Mar 30, 2022 | 06:51 PM
  #116
Hyakkimaru's Avatar
Hyakkimaru
Thanks, I appreciate it.
I decided I'm going to wait a little bit. Maybe something will come up this coming week and I'll be able to buy a new tube. With the new tube my current boots should work fine until I can get some new ones. Then it will all be proper instead of a bandaid fix. Thank you for your help everybody!
Old Mar 30, 2022 | 07:02 PM
  #117
RacinJasonWV's Avatar
RacinJasonWV
Edit: This was not in response to Tristan’s last post. He posted that while I was typing. This post now appears to be directly going against his just stated plan, but that is not what happened. Sorry!
Just buy the $20 boot. Most economical way to a solution. As you said, your current boot is toast anyhow. The $170 set of boots wouldn’t fix your issue anyhow without a new pipe.
Guys, this is what I was talking about earlier. Tristan needs an effective but cost friendly solution. I certainly remember buying parts while being 18. I truly feel this is an area he can save some coin with no problem. If it doesn’t work then he can use it to make plenum boots.
$20 4 ply boot
Sand paint off the pipe
Clean pipe& boot with brake cleaner
Smile
Seriously. I’ve made 34psi without a bumped boot. It’s not needed. Mine holds firm.
Took a trip to the garage and attic for some photos. My current no-bump boot is an inch longer than OEM. Tristan, I would probably go just a tad more in your case. It will position your clamp on an undeformed area of the pipe.
Old Mar 30, 2022 | 08:16 PM
  #118
Hyakkimaru's Avatar
Hyakkimaru
$20 4 ply boot
Smile
My original plan was that those boots would be my end all solution at least for a good while. I didn't think the bumped boots were necessary and I figured I could get some of those four ply boots a little longer and that would be my new boots for good and I would never have to worry about it again. I figured it would hold just fine and I wouldn't need a new pipe. Well you just wrote confirms that the non-bumped boot will hold my 20 plus PSI no problem. I've got some thinking to do. If I buy new riff Raff boots and a new tube I'm going to be in it for $240. I could buy two of those longer boots for $35 to $40 and just go ahead and replace both of my upper boots with that and have enough left over to do my plenum boots. Then all I would need would be the boots going to the intercooler which from riff Raff for just those is about 30 bucks. I would have all new boots for less than a hundred bucks. I know I sound like a recording at this point for saying that so many times but work has been so slow since October and I have been living off of 200 to $300 paychecks since then. That's a week anyway. $300 a week does not amount to much. Work has just been so slow. I've been doing work on the side a lot trying to make up for it but even still I don't have enough work. That's not saying I'm not busy it's just I'm not making as much money as I'd like right now. You said your non-bumped boot can hold 34 PSI with no problems. I will consider it overnight but I think that's enough for me to buy those instead and save 160 bucks. I will definitely weigh the options in for my current budget. Thank you for posting these pictures and thank you for your knowledge. That goes for everybody else as well, thank you all. I will figure out what is best for my uses hopefully by tommorow!
Old Mar 30, 2022 | 09:21 PM
  #119
RacinJasonWV
I think if you can find one 12” section it may be enough to do them all.
5” for the CAC and 7” left for the plenums. Sorry I didn’t measure those but could tomorrow evening.
Main thing to consider if going this route is to get the boot long enough to clamp back on a nice solid area of the pipe.
If you do need 2 and they offer free shipping then maybe just start with one. You can always come back for plenums later. Sometimes the shipping cost does make it worthwhile to add on an item though.
Edit: and I do think this could be a long term solution. Maybe I’m a cheap weirdo though.
Old Mar 30, 2022 | 09:30 PM
  #120
Hyakkimaru's Avatar
Hyakkimaru
I may end up being a cheap weirdo myself! (Please Don't take that as me saying you are one I'm just being funny, or trying to at least)
My plan was not to just fix the passenger side pipe but to also do the exact same on the driver side so they would be symmetrical. And I would also be fixing both of my old boots at the same time. So I will need 2 pieces. I figured if I got two 8-in ones and cut them both at 5 in for the spider to intercooler pipe I would have 3 inches left from each of them to do the plenums with. I will measure my plenum boots but I'm certain they can't be much longer than 3 in. I don't think they're that long. I'm not sure though. But, assuming they are 3 in, two 8-in pieces of hose will do the trick perfectly I think. Won't know till I try! I will try to grab a measurement tomorrow before I leave for work first thing in the morning. If I do decide to go the longer boots I think I'm also going to go ahead and put Blue on because that's going to be my whole theme anyway. Red and blue. Might as well start there. I think this is the one that I'm going to get since, earlier Eric said the boots he got were high quality and this is the same brand.
https://www.amazon.com/gp/aw/d/B09HBQGQFK/ref=ox_sc_act_image_1?smid=A13AI79XH2J53S&psc=1#
Thanks y'all!
