More problems😑
Old Mar 27, 2022 | 12:10 PM
  #46
RacinJasonWV's Avatar
RacinJasonWV
Originally Posted by Hyakkimaru
​​​​​​All good! Thanks anyway! Joel shot me a text saying I can get the extra inch of turning by adjusting the tie rod on both ends. Is this true? I feel like if the steering gear is maxing out it will only do so much. Could it be done?
Success! Fix my toe in and I'm turning lock to lock and my tie rod is not hitting my front differential case cover anymore! A good 2" from the case cover at full lock! The steering wheel is even straight without me having to adjust it at all. Ill call that a win all the way around!
The only thing that is not a win is yesterday when stepping off of the porch into our flower bed I landed on a rock and went sideways and sprained the crap out of my ankle. I heard a crack/pop and It is swole to twice its original size and hurts. But, it is what it is. Id that is all that went wrong over the weekend I think I can live with that!
Well a lot has transpired while I was away at church.
I was going to suggest fixing the bent tie rod and seeing where that left you before going all out for a bunch of new parts. But it seems like you already (half) did that and it’s working now. 👍
I would still consider changing out your bent collar. That worries me a bit. The strength may be compromised or there could be a hidden crack.
Didn’t you change the entire hubs recently? Remember to always check alignment after work which involved steering components. The new hub tie rod position won’t be the same as the one you too off.
Hope the ankle isn’t too bad and you’re feeling better soon.
Old Mar 27, 2022 | 12:17 PM
  #47
ESwift's Avatar
ESwift
CNCFAB
Hubs shouldnt change alignment, they attache to the knuckle, the steering components attach to the knuckle.
I do however recommend at this point, if possible, to have a shop that specializes in alignments and front ends to go over it to ensure safety of the components.
Old Mar 27, 2022 | 12:19 PM
  #48
Walleye Hunter's Avatar
Walleye Hunter
My steering wheel is off a little to the left but I like the way I can hold it whilst I rest my arm on the door's armrest so I just leave it the way it is.
Old Mar 27, 2022 | 12:23 PM
  #49
RacinJasonWV
Ah, I stand corrected. Oops.
Yes I agree with the alignment shop idea. Tristan I think this would be a good idea as soon as you can get the loose joints replaced. Otherwise they’d probably have a hard time putting it in alignment and it would then need done again.
Bad alignment is hard on tires. Tires are expensive.
Old Mar 27, 2022 | 12:46 PM
  #50
FordTruckNoob's Avatar
FordTruckNoob
Awesome! Now crack open a root beer and bask in the afterglow of a job well done. With the sprained ankle elevated.
Old Mar 27, 2022 | 01:12 PM
  #51
Hyakkimaru's Avatar
Hyakkimaru
I think I'm going to go with that Detroit Axle kit. Detroit Axle has some good stuff and for the $270 price tag for ball joints, tie rods, and sway bar end links, it's a pretty good deal. And a 10 year warranty to boot. That is next on the list. I do not plan on keeping that bent collar on there long. I do not like that kind of thing either. Too sketchy. As soon as I have my new tie rods and I will have an alignment done. I did just put hubs on thanks to Eric! Thank you all for following along with me!
Unfortunately, I can't sit down and prop up my ankle yet! I have a customer that needs a brake job! And then another job after that for a transmission fluid change and spark plugs. I got work to do! I can't be resting yet!
Old Mar 27, 2022 | 01:26 PM
  #52
FordTruckNoob
While I admire your work ethic, take it from someone who didn’t take the time to heal properly between jobs that it is important to heal first or you will find you will end up being able to do less and less.
Old Mar 27, 2022 | 01:52 PM
  #53
runningman777's Avatar
runningman777
thanks for the offer! I believe what I need is the 7 1/2" center to center. In hopes that it will let me actually turn the wheel all the way to the right which right now it stops about an inch short of. I thought something might be wrong and sure enough! I turn sharper to the left then I do to the right! Hopefully the 1-in longer pitman arm will fix that. If that doesn't fix it, maybe the combination of tight tie rod ends and the longer Pittman arm will take up that extra inch! The steering radius is bad enough on this truck when it works all the way, losing an inch is too much!
My pitman arm on my 2001 is about 7-3/8" Center to center.
Old Mar 27, 2022 | 06:51 PM
  #54
Hyakkimaru's Avatar
Hyakkimaru
While I admire your work ethic, take it from someone who didn’t take the time to heal properly between jobs that it is important to heal first or you will find you will end being to do less and less.
I understand that. Unfortunately I ended up getting hurt some more but what's new LOL. I was breaking a transmission drain bolt loose and when it finally broke loose I slammed my elbow into a cross member so hard that I have two elbows right now. Here I am four plus hours later and it still hurts and I still have two elbows. And my ankle hurts. Maybe I'll go to bed early tonight so I can get up and go to work tomorrow and maybe not hurt as much.
Good news though! My truck turns on a dime now. At least compared to how it was. I can turn out of my driveway and stay on my Lane without even thinking about going into the other lane. It turns sooooo much better. I can compete with those coil spring suspensions now LOL
Old Mar 27, 2022 | 07:15 PM
  #55
ESwift's Avatar
ESwift
CNCFAB
Ice those injuries for an hour before bed and then a but when you get up. Ice, ice, ice. You”ll be amazed at how much faster the inflammation goes down.
Old Mar 27, 2022 | 08:13 PM
  #56
petrokiller's Avatar
petrokiller
Yes settle down for an hour and throw ice on both your injuries.
Take several ibuprofen if you can/able every 6 hours.
Glad your steering is improved.
Old Mar 27, 2022 | 08:49 PM
  #57
runningman777
Glad to hear you got the turning problem worked out without having to sell your extra elbow. I've always had two elbows...
Old Mar 27, 2022 | 09:52 PM
  #58
Hyakkimaru's Avatar
Hyakkimaru
Originally Posted by Walleye Hunter
I have a drop pitman arm out there that came off of my truck when I de-lifted it. You can have it if you want it. You might want to glass bead the rust off of it.
I got everything taken care of for now but, I still want to thank you so much for the offer! I'm so lucky to have so many good friends!
Old Mar 27, 2022 | 09:53 PM
  #59
Hyakkimaru's Avatar
Hyakkimaru
Thanks for your help! That goes for everyone!
Oh yeah? Well, I have three elbows so ha
Old Mar 28, 2022 | 10:02 AM
  #60
Hyakkimaru's Avatar
Hyakkimaru
I recorded a video this morning of what my turbo pipe is doing so that everybody else can see what it's doing.
