2022 Tracking Spreadsheet
Old Oct 29, 2021 | 08:57 PM
  #2206
vtm204's Avatar
vtm204
Welp, today I picked up my truck. Couldn't be happier. Agate Black F250 Lariat CCSB, 7.3L w/ nearly every option except Adaptive Steering. Ordered 8/17, In production 10/7, Built 10/12, Shipped 10/13, Arrived at dealer 10/22, picked up 10/29.
Old Oct 29, 2021 | 09:36 PM
  #2207
Phoenixfla's Avatar
Phoenixfla
Originally Posted by M1078
Very nice job! Thanks for putting this together. If you had the time (and inclination) a very brief tutorial on how this is constructed would be great.
BTW I've noticed that just recently I'm not able to pull up any images of trucks from username. Used to be able to just hover over the username and a link would then appear below. Click and there was the image. Is that feature gone? Or just temporarily not working.
Regards,
Jared
I need to fix the images, it got out of wack when I had those extra rows showing up.
Do you want a tutorial how it is constructed, or how to read it?
I've thought of putting together a video of how to understand the different tabs.
The spreadsheet is assembled using data supplied by the users, some of the columns are created by Decoding the VIN, and most of the data is retrieved from the Ford Customer Tracking Database (not an official name).
Several times a day, Google sheets retrieves the JSON data from the server and populates the spreadsheet.
What you see is actually several spreadsheets coming together. The options are created using conditional formatting applied to the JSON data. Same with rear axle data.
The renderings are quite interesting. Ford has an image generator which generates an image with the submitted option string. I think I can trick it into showing frankentrucks but haven't tried yet.
The STP dates I enter manually by reviewing each window sticker when it becomes available. That data is not in the Ford info, but possibly the most important column on the spreadsheet.
Old Oct 29, 2021 | 09:57 PM
  #2208
Jonel's Avatar
Jonel
And what a fine machine it is when it runs the way you like it Phoenixfla.
you’ve done some great work here and the spreadsheet is a vital resource to the people that use it.
my Truck is somewhere in the Build right now. I think I have Warn your Spreadsheet out today watching for tonight’s update, lol. It will be done soon enough…
I’ll probably be out of hear in a few weeks or so. I look forward to posting a few photos for the group here.
Thank you Phoenixfla. I appreciate, with everybody else, all that work you do.
Jonel
Old Oct 30, 2021 | 10:03 AM
  #2209
ZipperMerge's Avatar
ZipperMerge
4th Gear
Nice looking truck!! I ordered one from Bickford in Snohomish back in June and it's finally in production
@Phoenixfla Thank you for building this sheet! Cool to see the additional info. Not sure how to 'user populate' but the dealer told me my build week was 10/18.
Old Oct 30, 2021 | 11:39 AM
  #2210
M1078's Avatar
M1078
I would be interested in a tutorial on how it is constructed and how the data is pulled from the different sources. Maybe a little on how JSON data works.
Old Oct 30, 2021 | 02:40 PM
  #2211
Phoenixfla's Avatar
Phoenixfla
Thanks!
Here is the link to submit your build date:
https://docs.google.com/forms/d/e/1F...Z0JlA/viewform
Old Oct 30, 2021 | 02:55 PM
  #2212
Phoenixfla's Avatar
Phoenixfla
Where do I begin?
I was inspired by the "view raw data" button on the bottom of the Mach e tracker. As I researched it more I discovered that when a query is made to the Ford database it returns a large string of Json data. When you click on that button on the Mach E tracker you can see a lot of the data that is available.
I knew if I could get that into a spreadsheet it would allow me to track a lot more vehicles as before I wouldn't have to manually track each truck each day which is what I was doing on a small scale.
So I spent an enormous amount of time trying to figure out how to pull that Json data into Google Sheets. I read tutorials, watch videos, and studied up in general and struggled, for weeks, I tried 5 different add ons to Google Sheets which should have retrieved the data and imported it into a spreadsheet. Nothing worked. I had emailed the creator of the Mach E tracker and the Ford F150 tracker with questions. I could not figure out the missing piece.
I finally struck gold with a add-on called "SyncWith". It works fairly well but I still get a fair amount of errors but those could be from the Ford database side.
If you want to try building a spreadsheet then read up on how syncwith works and set it up to where the order number and VIN numbers are the two variables that are submitted to the API. Syncwith allows hourly, daily or manual updates. I have it set on hourly but it doesn't reset the timer until it completes the last update so it's actually more like every 2 to 3 hours. Plus sometimes it gets hung up and I have to manually kickoff an update. Once you get the data imported then it's just a matter of sorting it, color coding, organizing and applying conditional formatting.
I'd be happy to help someone set one up, but I've got to warn you, its a lot of work. I know the Bronco community would really appreciate one, maybe mavericks too.
Old Oct 30, 2021 | 03:42 PM
  #2213
M1078's Avatar
M1078
OK Thanks. Not looking to set one up right now but was interested in what's behind the scenes. Even more impressive considering that you had to put quite a bit of effort into figuring it out. If I do ending up wanting to put one together I'll take a stab and then ask more specific questions. Would be a great subject for a YouTube video.
Old Oct 30, 2021 | 05:01 PM
  #2214
Sean1012's Avatar
Sean1012
Window Sticker
Wondering if not having a window sticker 2 days before schedule week build is normal? I just have a feeling it's been pushed back however my salesman tells me everything is still on track. Anyone experienced this?
Old Oct 30, 2021 | 05:15 PM
  #2215
camping nut's Avatar
camping nut
Originally Posted by Lariat Driver
I've been moved SEVEN times!
Ordered July 29, originally scheduled for build week of Sept 27 then
Oct 4
Oct 18
Oct 11
Oct 18
Oct 25
Nov1
now at Nov 8
F-250 SCSB, 6.7L, 3.55 ELD, TTHC 53Q, 5th wheel prep, wheel well liners. If something has been listed as a shortage over the past two months, I think I have it on my order.
Oh wait - NO Adaptive Steering!!
Not quite there but working on it Just thought I would add to the fun Platinum no adaptive steering(plus I have a limited on order May 10 and no serial number)
Ordered April 23
- Build week Oct 25
- Scheduled day Oct 28
- Build week Nov 1
- Scheduled day Nov 3
- Build week Nov 8
- Scheduled day Nov 17
- We will see
Old Oct 30, 2021 | 05:19 PM
  #2216
(Overthebars)'s Avatar
(Overthebars)
Took delivery today loving it so far
Old Oct 30, 2021 | 06:54 PM
  #2217
mikejones202's Avatar
mikejones202
Where's the pictures??? Congrats!
Old Nov 1, 2021 | 09:12 AM
  #2218
Buckstop's Avatar
Buckstop
To good to be true
When I ordered my 2nd truck on 10/13 code 10 i received my vin and build week as 11/8 the next day. I received notice sunday that I have been moved to 11/15. I knew that first build week was too good to be true. I hope I dont go through what some of you have. Mine is a simple build, xlt screw nothing special in options rw liners,bed mat, premium chrome pkg., 7.3
I dont think the first truck was even ordered. I have never been able to get info from dealer or ford cs. I placed 2nd order with a different dealer. X plan buyer
Old Nov 1, 2021 | 12:43 PM
  #2219
DCKoyen's Avatar
DCKoyen
Going to whine for a second...
Did I set a record?
Sent to plant-Production date = 12 days
Production to build = 19 days
Released 10/30 - still awaiting shipment, delivery 11/27-12/3
Old Nov 1, 2021 | 12:59 PM
  #2220
bsmith993's Avatar
bsmith993
I don't know why but this got in my head so I had to meme-ify it...
