Sponsored by: Real Truck
My LED bulb replacement thread
Old Oct 16, 2019 | 11:36 AM
Overkill2's Avatar
Overkill2
Just for size comparison. These do fit in the factory housings but don't seem to snap in as tight as the OEMs. Like I said, they look really great on my black roof, but they diminish the brightness too much. Personal preference I suppose. Here's the link to them. I was going after a darker cover because I thought the brighter LEDs I have in there would hold their own.
https://www.amazon.com/YITAMOTOR-Clearance-Aftermarket-Replacement-Compatible/dp/B01M5DCU4R/ref=pd_sbs_263_3/145-2274779-3394362?_encoding=UTF8&pd_rd_i=B01M5DCU4R&pd_rd_r=d4eaa45a-8e07-4e92-b759-faf6bbd4f4fd&pd_rd_w=YBRTf&pd_rd_wg=r430z&pf_rd_p=52b7592c-2dc9-4ac6-84d4-4bda6360045e&pf_rd_r=E3DKG1TD271NK7A0XSKG&psc=1&refRID=E3DKG1TD271NK7A0XSKG https://www.amazon.com/YITAMOTOR-Clearance-Aftermarket-Replacement-Compatible/dp/B01M5DCU4R/ref=pd_sbs_263_3/145-2274779-3394362?_encoding=UTF8&pd_rd_i=B01M5DCU4R&pd_rd_r=d4eaa45a-8e07-4e92-b759-faf6bbd4f4fd&pd_rd_w=YBRTf&pd_rd_wg=r430z&pf_rd_p=52b7592c-2dc9-4ac6-84d4-4bda6360045e&pf_rd_r=E3DKG1TD271NK7A0XSKG&psc=1&refRID=E3DKG1TD271NK7A0XSKG
It looks brighter ( the dark cover over the driver's seat ) but it really cuts down the output of those LEDs.
I'll see what my next move will be on the cab clearance lights.
I may buy these because they have covers along with bases, gaskets and hardware. One OEM clearance light with base/cover is around 20 dollars I believe. Like an idiot, I torqued a screw down too tight and cracked the rear of the driver side base. Had it JB Welded and re cracked it again.
https://www.amazon.com/dp/B07HDZWVJM/ref=sspa_dk_detail_3?psc=1&pd_rd_i=B07HDZWVJM&pd_rd_w=5ef4m&pf_rd_p=45a72588-80f7-4414-9851-786f6c16d42b&pd_rd_wg=wHIB0&pf_rd_r=NFB7AYMY1KQMNWYJ1BDT&pd_rd_r=28921626-7fc7-411c-aabb-82b911c3df59&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFLQjlFRFM5N0VZN0MmZW5jcnlwdGVkSWQ9QTA1MDYxNTQyWlUySVJONUZTSFRIJmVuY3J5cHRlZEFkSWQ9QTAzNTU3MTM5VTYwUllFWDJQOUMmd2lkZ2V0TmFtZT1zcF9kZXRhaWwmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl https://www.amazon.com/dp/B07HDZWVJM/ref=sspa_dk_detail_3?psc=1&pd_rd_i=B07HDZWVJM&pd_rd_w=5ef4m&pf_rd_p=45a72588-80f7-4414-9851-786f6c16d42b&pd_rd_wg=wHIB0&pf_rd_r=NFB7AYMY1KQMNWYJ1BDT&pd_rd_r=28921626-7fc7-411c-aabb-82b911c3df59&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFLQjlFRFM5N0VZN0MmZW5jcnlwdGVkSWQ9QTA1MDYxNTQyWlUySVJONUZTSFRIJmVuY3J5cHRlZEFkSWQ9QTAzNTU3MTM5VTYwUllFWDJQOUMmd2lkZ2V0TmFtZT1zcF9kZXRhaWwmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
Old Jan 30, 2020 | 07:46 PM
Overkill2's Avatar
Overkill2
Originally Posted by Shovelheadrob
https://www.atomicled.com/proddetail.php?prod=F0009S
The site won't accept a video (wrong format) but here's a still. They ain't cheap but........they sure are bright. They also do an led third brake light/bed light with strobes.
I never commented on the fact that you rock A Ford dually in England, but that's pretty fukn awesome. You must get some looks for sure...
I will be bringing this thread back as I've bought VLEDs front and rear 3157 Extremes over the holidays because of the money I saved on them with their holiday sale. I also bought one of their reverse lights that goes over the rear plate. Stay tuned...
Colorado350
31
Dec 18, 2023 06:26 AM
NorthwesternCowboy
Washington Chapter
Nov 16, 2019 06:04 PM
jayro88
Oct 7, 2017 11:31 AM
Big-Foot
All Things Towing
35
Jun 26, 2016 04:29 PM
rayofsi
Feb 16, 2013 04:20 PM
