Yep, it was only a few inches below the surface. I've spliced coax before, but it has been many years. I might be tempted to try to fix it myself temporally, but I have lots going on. And there is so little daylight now.
The break is annoying, but the kid that did it felt bad and people make mistakes.
I just have to get the electrical contractor to call me back. We don't need to run lines now, but I would like to have a play laid out. Especially to make sure the conduit is in the concrete at the proper place for running the line later.
They are actually moving a little fast for me. I'm using the money on the sale of my in-laws house (to my daughter) to finance this project. At best, we will close on that house the end of December. Good thing I'm a member of a Credit Union, much easier to deal with for loans. Especially one that will only be for a couple of weeks to a month at most.
It won't be long Joe! Remember the days you had to let air out of your tires to get your F250 out of the garage?
LOL! A lot has changed since then. At one point I only had a pancake compresses as well. It took me 30 minutes to get the truck out of the garage for a drive.
My wife says she loves her new house sometimes several times a day. So, hopefully we will be here for a long time.
The progress looks great Joe! It's obvious those guys have a lot of experience and the right tools to do flat concrete work.
This summer I buried 3" conduit 36" deep to put my power line underground. It's REA and we're in the country - they approved the project.
I dug under the neighbor's cable, my old (live) power line, a septic line and what I thought was the phone line. Didn't cut anything I shouldn't have, but it turned out the phone line was re-routed sometime in the past and I spent a lot of time hand digging to find the thing only to realize the line was abandoned.... it's not there now
I hope your project is smooth sailing with no bumps in the road!!
The person I bought our from was a real thinker, planner. He had three conduits run between the house and the pole shed. One had all of the high AC wiring, one was for the communication wire and a spare with a pull cord. He had the entire place wired for internet, phone and other, at the time, state of the art electronics. Now most of it is a waste because of wireless communication and blue tooth. I went around and pulled many of the old wiring out and patched the walls where he had boxes in the walls.
The AC electrical he had pulled is nice. I have a 200 amp service in the pole shed and I pulled an internet cable into the shed to a router for better internet in the shed.
Joe,
Great progress! Have you had any neighbors checking out the project and feedback? When I built my shop 26 years ago a neighbor was very alarmed seeing the vertical board and batten which was very light colored asked my contractor if it was going to be painted to match the woods. He wanted to tell her that it was going to be chartreuse. It was stained gray about 2 weeks later.
Looking good Joe! Are the garage doors going to be on street side or driveway side? Just curious if you have to do a curb cut or not? Also sun exposure is important for snow and ice melting. At least it is here in Nebraska.
Joe, I have an off topic question. I was reading about Times Beach MO last week. Are you old enough to remember that, do you live anywhere near that? Dennis
The garage doors will face the road and the curb will have to be cut. That added $500 to the bill. The driveway faces a southeast direction so I will get some winter sun. Yes, that exposure is very important. In my old house, you could easily see where the house blocked the sun in the yard as the snow was melting.
Yes, I was a freshman in high school when that happened. Times Beach is about 2 hours from me close to St. Louis. BJ is pretty close to there. Not sure if he was in that area then though.
It was all over the news for quite a while. We all learned about Dioxin at that time. Since I was 14, I was fairly oblivious, but it was hard to miss.
Very nice! What is your sidewall height?
With the cost of all this, I might have to wait a little before I get my lift. Expenses keep adding up.
Yes, I know what you are talking about. I bought a business condo ten years ago. I got in before the start of the development and was able to have my building custom made the way I wanted it built. The money just flowed out. I was going to go with in floor heating in the shop but wasn't in the budget. Glad I didn't though, with the overhead tube heat I think I got the same benefit. Also, I hadn't planned on installing a lift so the grid for the heat system would have caused a huge problem.
As for a lift, don't rule out used. I bought my lift used for $2000, it came with a lot of other things but you should be able to find used lifts in the $1000+ range. Just have to make sure it's a good quality unit. Check out auction of dealerships and Walmarts, they're a good source of used units. Believe me, a lift is worth every penny, you back will thank you the first time you lift a vehicle to repair.
