Excursion Sport Build
Old Feb 17, 2021 | 06:59 AM
  #166
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by brokestroke
Or skip the last 2 steps and make another T4 kit?
Hey don't chicken out now!!
Old Feb 17, 2021 | 07:03 AM
  #167
brokestroke's Avatar
brokestroke
Post up some pics and videos of the other project that distracted you from the Ex man. I'm curious.
Made a deal with Sous and he shipped me his HPI Savage RC truck. Unfortunately the motor was locked up and I cant help myself sometimes.
So I stretched it with a custom frame and bought a 27.5cc 2 stroke motor.
Video of it running after break-in.
Getting close to being driveable, going to build a full roll cage and body for it.
Old Feb 17, 2021 | 07:09 AM
  #168
FordTruckNoob
Holy crap that's a lot more engine than it used to have.
Old Feb 17, 2021 | 07:36 AM
  #169
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I am so very grateful the RC Savage went to you and your family! I am so glad we didn't donate here locally and pass along an issue that we didn't know about to an unsuspecting kid or adult kid.
Thank you for giving this truck another chance at life. After sending it to you and your family and discussing with you what was going on, it makes sense as to why I couldn't get it started the last time I tried years ago. I think 2017 or 2018 was the last time I had it running, I'm not sure to be honest. Our land is not setup for an RC truck that does 45 MPH quickly.
I am glad that the packaging material worked out, I have not had to pack a large RC truck like that before, so I was doing my best to ensure a safe arrival.
You turned it into an entirely different beast though and both my wife and I are very excited for you all.
Have fun with it and we would still love updates as the time goes on if you are able to!
Old Feb 17, 2021 | 09:03 AM
  #170
brokestroke
...must..stay...focused...
Old Feb 17, 2021 | 09:05 AM
  #171
FordTruckNoob
Stay on target...
Old Feb 17, 2021 | 09:10 AM
  #172
brokestroke
Holy crap that's a lot more engine that it used to have.
Stock motor was 4.6cc, so 22.9cc larger. The transmission may need to be replaced with something larger. Trying to keep the weight down so it doesn't tear itself up too much. I was all , then started and heard it run for the 1st time and then I was
Old Feb 18, 2021 | 03:28 PM
  #173
brokestroke
Old Feb 18, 2021 | 03:42 PM
  #174
Sous's Avatar
Sous
FTE Emeritus
Amazing to think that work of art was sitting in my basement in a box a couple of months ago...
Looking nice sir!
Old Mar 25, 2023 | 06:31 AM
  #175
FordTruckNoob
What's the situation with the compounds on the Ex?
Old Mar 25, 2023 | 08:53 AM
  #176
brokestroke
The old girl has been down in Florida for a while but I am going to pick it up tomorrow. Have been giving it a bit of casual thought and if an S475 landed in my lap, well...
All the Coolant lines under the hood need to be re-routed (mainly the ones on the passenger side of the engine bay), probably cut out and replaced with something that is not pre-formed. Both batteries should be mounted in a tray on the frame rails. IMO the degas bottle should be removed and built out of aluminum and remounted where the driver's battery was (or close). This next part I am not sure...The little vacuum pump on the pass. side behind the battery that runs the factory locking hubs. Can that be removed (have aftermarket hubs) or does that control the heater blend doors as well? Low mount oil fill like what an OBS 7.3 has. For the mid-pipe coming off the high pressure turbo I figure 3" and no bigger. Easier to route up into the engine bay, big turbo where the pass. battery and vac-pump were mounted. Lots of things I would like to try but with KC dropping a line of S300 wheels a T4 setup may not be out of the question and getting my hands on a Turbonator may push me to want to run one on multiple applications.
Not a 7.3 but the guys at Power Driven Diesel (cummins guys) have a neat video of building a compound setup on a 6.0 PS. Ill find the link.
Old Mar 25, 2023 | 09:41 AM
  #177
brokestroke
Here is the link to the compound build, straight up guys, no drama or BS. Although with a Cummins they have tons of videos of different turbos and combinations running on the dyno, with a good amount of detail and information on each setup.
Old Mar 25, 2023 | 11:37 AM
  #178
SkySkiJason's Avatar
SkySkiJason
The vacuum canister keeps the pump from running all the time. A canister could be put literally anywhere.
1994F2507.3L
120
Mar 4, 2015 06:40 AM
Stephanie-7.3idi
Jan 10, 2015 09:45 PM
Wood.
Jul 20, 2013 08:09 PM
Krisx125
Mar 13, 2010 09:40 PM
oldgameandfishdiesel
Sep 2, 2009 11:12 PM
