Excursion Sport Build
Old Oct 24, 2020 | 12:03 PM
brokestroke's Avatar
brokestroke
I'm not sure I understand the moving the battery and cold pipe part. Can you elaborate please?
On second thoughts, let's just stack the turbos vertically and have them sticking up out of the cowl/hood.
Taking a look at the packaging it appears that a 2nd turbo would fit best on the driver's side with the battery moved. This would cause a challenge for the down pipe though.
Old Oct 24, 2020 | 12:37 PM
FordTruckNoob's Avatar
FordTruckNoob
Hmm, that’s a lot of tubing between the turbos.
Old Oct 24, 2020 | 12:43 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Seen this yet?
https://www.dieselworldmag.com/featu...-power-stroke/
Old Oct 24, 2020 | 12:50 PM
FordTruckNoob
I just spooged myself.
Old Oct 24, 2020 | 12:56 PM
Sous's Avatar
Sous
FTE Emeritus
I sometimes listen to these guys when traveling. Not many pictures, but you may be able to glean some information from the podcast.
Old Oct 24, 2020 | 12:57 PM
brokestroke
Trying my best to maintain stockish fitment and the excursion has some extra coolant lines on the pass. side that make it difficult.
Old Oct 24, 2020 | 12:59 PM
brokestroke
Maybe a touch longer on the exhaust pipe but shorter on the intake plumbing and more room for an air filter.
Old Oct 24, 2020 | 01:01 PM
Sous's Avatar
Sous
FTE Emeritus
Another website with images...
https://ultradieselperformance.com/p...d-turbo-system
EDIT: I'll stop posting sources unless I find something that is more in line with OEM configuration.
Old Oct 24, 2020 | 02:00 PM
brokestroke
Going to be a long process so might as well start on something. The collector is going to be T4 open scroll.
Old Oct 24, 2020 | 03:49 PM
FordTruckNoob
Whoa. That went from concept to development pretty darn quick. You'll have this thing done before I complete my T4/SXE conversion I think.
Old Oct 25, 2020 | 07:24 AM
brokestroke
Long way to go but its a start anyways. Got my bandsaw going so that will help with the tube work.
Got some parts coming for the Ex to get everything up to snuff.
RR FPR spring
RR plenum boots
RR IC spider boots
RR plenum reinforcers
T-bolt clamps for everything
Will likely pick up some Bellowed Up-pipes too.
Also leaning towards a 1.0ar turbine housing to keep pressures relatively in check.
Old Oct 25, 2020 | 07:29 AM
ESwift's Avatar
ESwift
CNCFAB
RR FPR spring
RR plenum boots
RR IC spider boots
Lemme known if you need a 1.0, I have one from a 38r on the shelf
Old Oct 25, 2020 | 07:34 AM
  #28
brokestroke
10-4, will probably order one today unless your deal is a better one.
Old Oct 25, 2020 | 07:35 AM
  #29
ESwift's Avatar
ESwift
CNCFAB
Pm me an offer, I have zero use for it, and am willing to offer it reasonably to assist with the coolness factor of twins.
Old Oct 25, 2020 | 07:52 AM
  #30
FordTruckNoob
I have a wrapped set ready to go.
